8" jointer
8" jointer
8" jointer
Don
I was able to purchase some very nice old Honduran Mahogany boards rough cut 8" wide and hate to cut them down to 6". So I am going to buy an 8" jointer. Does anyone have any experience with the new carbide spiral head machines? Also read a good review about the grizzly which is less expensive than a powermatic or delta. suggestions welcome.
Re: 8" jointer
Re: 8" jointer
Howard Norman
I have had a Grizzly G0490 8" jointer for five years now with conventional knives. No complaints after a shipping issue got resolved.
Re: 8" jointer
Re: 8" jointer
mdclor
Don,
I have the Grizzly G490X and have been very happy with it.
HTH,
Merle
Re: 8" jointer
Re: 8" jointer
FredD
, I am on my second DJ20 and this one is X which has a warranty of five years now.
I also had it fitted with a Shellix Byrd carbide insert cutther and let me tell you from years of using a jointer , that cutterhead is the only way to fly. No more treart in squirrely grain.
The DJ at the time I got it , did not have a Shellix head option though Powermatic does.
It is well worth the extra bucks and inserts may be the last you ever have to have sharpen due to the length of the edge life and naturally four edges to each insert.
FredD
Re: 8" jointer
Re: 8" jointer
If you contact Byrd, you will find that they do sell aftermarket heads for many jointers. So don't just limit yourself to a new jointer. You can find a good quality used one and replace the head. As I recall, they run about $450.
Re: 8" jointer
Re: 8" jointer
McKay
I have a dj20X and have put a shelix head on the jointer. The "X" is a great machine and there are hidden things that you need to be aware of. The PM is a nice machine, but having had one when I taught, I can tell you that the electronics are poor. I have a friend at another local high school that has had similar problems. I would guess that most of the less expensive jointers will cut corners by having less quality motors and electronics. Now that I am retired, I use the jointer ever day. If you are only using the jointer sporadically then any of the jointers would be a good purchase. By the way, I purchased my Byrd shelix from Grizzly. They are less expensive than purchasing the same head from Byrd. Go figure.
Re: 8" jointer
Re: 8" jointer
John in NM
Grizzly gets good reviews, and the one I've used was a good jointer. You can also face joint an 8" board with a 6" jointer, you'll need that knowledge with a 12" board and an 8" jointer as well. One shop I worked for had a 12" jointer and wouldn't you know, we came up with some 16" boards that need jointing :D
I don't think you need a spiral head, unless you have the $$$ and want it. They are nice and have many advantages, but you can buy a lot of wood for that $450 or whatever it adds. Get an extra couple sets of knives and change them often instead, you'll get good results doing that too.
However, if you're doing full time work for money, the carbide head is the way to go. They save time on knife changes and reduce time spent sanding when the wood is prone to problems.
Re: 8" jointer
Re: 8" jointer *LINK*
Jim Dillon
Don,
Can't answer your question directly, but the latest issue (Feb) of Popular Woodworking has a very nice review article by Glen Huey on upgrading your jointer/planer with the spiral blades. He discusses the pro and cons of the different spiral designs and how one's work habits may govern having the blades in only the jointer, planer, or both. FWIW, he decided to only replace the blades in his planer. Sorry I couldn't be more helpful.
Jim
Upgrading
Re: 8" jointer
Re: 8" jointer
Don
Thank you everyone that responded your input was helpful Don
Re: 8" jointer
Re: 8" jointer
Steve In Phoenix
Do this at your own risk, but it works like a charm:
1) Remove the guard from your jointer. Make sure the knives are flush or just a little beyond the outfeed table edge.
2) Flatten one side as normal. You will end up with a little lip where it hangs off the edge.
3) Cut a strip of 1/4" plywood just a bit longer than the piece you are about to plane. Staple a strip of plywood along the back end of the "sled" to act as a stop.
4) Place the jointed side down on your sled, with the lip hanging over the edge. And the rear end of the wood butted against the stop.
5) Plane as normal. Remove the planed piece from your sled, flip it over and plane off the lip left from from the jointer.
