We value your privacy.
New article up by Virgil Johnson about setting up a planer. We are getting back in the saddle again and encourage anyone to send in articles that you might want to write. (hint, hint) Take a look at the new one, good stuff there for anyone that might want to set one up. Good info on installing a Byrd head also.
Virgil it sounds like you had to do a fair amount of machining. My abilities in this area are limited to a file for rough edges. What is your opinion of the machine and cutters without doing the extra?
I like the finish from the Byrd cutter head and nothing so far about the machine has made me regret buying it. In all I machined three parts. The first was bearing retainer area on the gearbox casting. My guess is there are thousands of these machines running just fine the way they came from the factory. I had the chance to close a gap while I had the machine apart and chose to do so. Same with cleaning the paint off the gearbox bore/end. Unless there was a problem I would not tear my machine down to check..:-) The second was the key. The key could have been fit with a file. I could mill it so I did. The third and biggest part was the exit roller. The exit marks were an issue for me and I chose to take a risk and machine them off. The reply from tech support was the exit roller serrations may have been too sharp on the crest.
