OT - Computer Problem
Ralph Lipeles
I have a 2 year old Dell laptop running Windows Vista. I turn it off using the standard icon at the bottom of the screen, left side. Right after I turn it off, a minute or 2 later, it turns itself back on. Any ideas on how to fix this?
Thanks,
Ralph Lipeles
Re: OT - Computer Problem
Is the "restart" option checked?
Dave Bair, Eaton Rapids, MI
John McGaw
Are you really turning it off or are you putting it to sleep or are you telling it to hibernate? All three of these are possible. If by 'standard icon at the bottom of the screen, left side' you are speaking of something which appears after the 'Windows' symbol is clicked in the taskbar then we have a starting place. When the standard start menu opens there is a triple icon which shows up showing what appears to be a standard 'power' symobl, a lock symbol, and a right-pointing arrow symbol. By default the 'power' symbol does not actually turn the computer off -- it just puts it to sleep. If you click on the right-arrow symbol you will be given choices of what to do and selecting 'shut down' there truly shuts the computer off. It is possible in the control panel to change what the 'power' icon does IIRC. It is also possible to change what the computer's power button (and standby button if it has one) does in the control panel.
As for waking up, in the control panel there is an option of 'wake on LAN' and if that is selected and the computer is merely sleeping, it will turn itself back on. If you have any sort of network connection, wired or wireless, this could be what is turning the computer back on.
Bill Howatt
When the system shuts down a lot of stuff has to run properly before the shutdown is achieved. If something gets and error it can cause a problem.
I don't know about Vista but in XP if you go to My Computer -- Properties -- Advanced there is a box labelled startup and recovery. Inside the box there are some options one of which is Reboot or restart on error. See if it is checked.
Bill
