We value your privacy.
I messed up my drawers and they are not flat. The photo shows what I mean. Three of the corners of the drawer are touching the surface, and the near left one is raised up by about 3/8". How do I flatten it now?
Clint and Fred are right. Start over. Check your stock prep very carefully.
You CAN run a drawer over a large jointer and "flatten" the box, but that would work if the drawer were off by a 1/32 or 1/16". If you were to dress this box until it was flat it would be at least 3/8 shorter than it is now and the dovetails would be all out of whack. (Whack being a highly technical woodworking term.)
Why not try to take out the twist. Block it up an 1" or 1 1/2" just like you have it (heavier clamps though), then take a clamp and pull the high corner all the way to the bench. Let it sit a couple days and see what happens. Mabye the glue will creep, maybe it won't. If something breaks, or it doesn't work, so what, You have to start over anyway.
Either that, or save it for some of that wonky art furniture with twists and curves.
This might be a glue-up problem. Assuming your stock was well prepared, make sure your clamps are on a flat surface and that the entire drawer box is snug to the clamp surface. I have had this happen, though not as large a gap as your drawer. But the result is the same, a wobbly drawer. Since then, I really try to pay attention to this small but important detail during glue-ups. Good luck.
It looks to be a drawer like for a kitchen cabinet, that would usually have some variety of metal slides. If one were to screw an Accuride on each side of this drawer they would pull it into submission without additional attention.
I would add that drawers made with 5/8" or 1/2" material look more refined and for a kitchen I like to bull nose the top edge a bit. Also I like to finish them with a thin coat of some finish, a recommendation that is sure to set off protest.
Since this is for a workbench how about gluing a shim to the bottom (high corner) and planing it down and then planing off the high corner on top? Cobble shop 101...I have much experience here. As a bonus the round tools will roll to the front where you can get at them easily.
I may not be seeing the pic correctly, but it appears as if the box and face are seperate.
remove the box, from the face and check the box. If it is flat and square then the problem lies elsewher. If it is flat, then check the face and make sure it is square and flat. You may be able to plane the box front to make it square with the face, or you could try a full face tapered wedge on the box. Try all suggestions prior to starting a new box. Learing how to correct, or improve a BOO BOO, is a good learing tool.
I went another direction on this. Instead of planing, or shimming the drawers I mounted the sliders to compensate for the twist. The face had a �� overlap on top and bottom which I cut off so I could insert shims more easily (I know, I said I didn�t shim it).
Next I put something into the drawer slot to rest the sliders on. For the bottom slot it was a piece of wood just a little bit longer than the length of the area I was working in, for the ones above that it was the drawer that went in the slot below.
My sliders consist of 1� high wood that I affixed to the plywood on the sides of the drawers. I put a 1/8� spacer on top of the drawer below, then the slider for the next drawer. I leveled the face then I slid shims under the spacer until the sliders were touching the drawer. Then I carefully removed the drawers and clamped everything down so I could screw and glue the slider in place. The spacers and shims were removed at this point.
Now I�ve got 1 1/8� gaps between the faces. The bench top is hard rock maple salvaged from a bowling alley and has the mahogany dots in it. This is relevant because I�m going to trim out the space between the faces with some jatoba I have left over from trimming the sides of the bench top. The jatoba trim is to make everyone else in the world think that I cut the faces that way on purpose to match the bench top.
The downside of course is that each drawer is customized and will forever be in that one slot, no moving it arond. I've marked the drawers and slots to keep track of what goes where.
And for the photographers out there, I�m pretty happy with the photo I took showing the problem. I used a two-light setup with my SB-600s, you could say it was a three-light setup if you include the pop-up flash on my D300, but I usually turn it way down and only use it to control the other flashes. My main light was an SB-600 with a dome light modifier on the left. My secondary light was an SB-600 bounced off of a silver reflector to the right to make the shadows a little more subtle.
