We value your privacy.
I'm working with a friend to cut a few pieces of 1/4 brass stock and one piece of 1/2". I need to remove the center of a 1/4" piece, and then cut an outside profile on the rest. I'm thinking a hand held jig saw to get close, then a router and a template to make them all the same. I've heard a router works for this, but never saw much about bits or speeds. Any thoughts?
I've cut aluminum with a router, it works well but is about the most unpleasant thing you can possibly do with a router. Bit speed you want as slow as possible, if you have a variable speed router. Your lowest setting is likely to be about in the range of the highest settings on a milling machine. I'm assuming you're going to use a pattern bit? Not many choices there, straight cut carbide is about it.
I would use a bandsaw first to rough it out, then a carbide upcut spiral bit, which is really and endmill in disguise. Put your router on its slowest setting. A collar in the router would follow the pattern and you could do almost anything you can do it wood. Just take it slow and small bites.
. . . is there any chance of brass chips falling into the router (assuming it's being used in a router table) and winding up between two electrical parts that weren't meant to have a conductor between them?
Use the handles on the router with patterns and small cuts it's really very easy to control.... Trouble is the noise, absolutely awful, and screaming hot chips flying everywhere.
Button up shirt with long sleeves is a must, leather gloves with rubber bands around the wrists, face shield over googles, and ear plugs with muffs over them was my standard setup. If I never have to cut metal with a router again I'll have one more reason to be happy.
You didn't give the dimensions of the piece nor the internal section you wish to remove, so I'll only speak to your idea for using a jig saw.
Firstly, mount the hand-held saw onto a sheet of plywood with the blade protruding through a zero clearance slot*. Invert this makeshift saw table and fasten securely. Use a fine-toothed metal cutting blade (preferably made for nonferrous metals). Using a power tool speed controller (such as used on fixed speed routers) set to its slowest speed and with the orbital cycling on your saw set completely off, saw with a slow feed rate and light pressure.
Depending on your saw, the blade and your technique and assuming 260 brass (cartridge brass), this might work well enough for you. It will not be pretty, though, so expect to do some filing to your line. Also, when sawing and filing, wear a mask and thoroughly wash your hands as 260 brass contains lead (although not nearly enough to make it as machinable as 360 brass).
Know that there are better ways to do this.
*If you must use the saw to cut to the center of your plywood saw table, you must reinforce the kerf from the other side with a glued-on scrap board. Less preferable, spray cement and back your workpiece plate with thin plywood and cut through both, plywood side down, of course.
if you have access to another friend who happens to be a gunsmith or a machinist with access to a mill, your project will be much easier. A mill is vaguely like an inverted router. And it is designed to cut metals.
The workpiece is attached to the table and the table is moved under the cutter.
I've done a bit of this after sweating and losing sleep over how. The piece I made was thinner and larger. I decided to sandwich it between some 3/8" mdf using double-sided tape and clamping it well here I could with screws. My cuts were with an edge guide, not the router table. I didn't do a cutout though. If I did, I might have made a pattern sandwich and coped out the cutout first. And, yes the chips were hot..
Have you considered setting up your drill press and useing it like an overhead pin router.
I have done this several times, and used a mill cutter. Sometimes I had to play fround with the pattern to get it to match. Your pin size needs to be the same size as your cutter.
Remember that the bearings on a drill press are not made to resist lateral milling forces and can quickly lead to considerable spindle damage and permanent runout. That said, Joe's right, it can be done. Just be aware of the issues.
End mills are quite hard throughout and can be dangerous in a 3 jaw chuck. Hard means the chuck can't grip as well so having a flying end mill is a real possibility.
Not saying it's impossible, I did it often until I learned otherwise.
