Laying Formica Tops
Laying Formica Tops
Laying Formica Tops
Jerry Draper
I need to repair a formica table top that has a major chip in it. After I repair the chip can I lay new formica over the old or do I have to remove the old formica?
Re: Laying Formica Tops
George Koch
Jerry, Ive done it often. Just sand it down and clean it off with acetone or the like before proceeding. George
Joseph Mulherin, Sr
Yes, Jerry, you can. Like George said, sand the top and then apply contact cement to each surface...let setup till tacky...then lay slats across the present top and lay the new formica on the slats...then remove slats from the end first and apply pressure to rid all bubbles. Continue removing slats and eventually the new top will be in place secured with the contact cement. Then use a router and formice edger to dress up the table edge as needed.
Router
Jerry Nicholson
and after you use that router on the formica edges, DO NOT touch that edge until you have run a file along it at about 45 degrees. The router bit will create an invisible burr that is super sharp and could cause you to get blood all over your new work. I don't really have to explain how I know this do I? :(
Jerry
Re: Router
Joseph Mulherin, Sr
Yes, Jerry, I found out the same way earlier in my life....and it only takes once to learn....
Re: Router
Jerry Nicholson
I just wish I could get my tools that sharp! :D
Jerry
Thank you very much.
Jerry Draper
Bevel
Howard Acheson
Why wouldn't he finish off the job by running a 45 degree bevel bit around the top? That's the way plastic laminate is generally finished off. In fact "Formica Router Bits" generally consist of two bits. One is a flush cut straight bit for the initial sizing and the second is a 45 degree bevel bit for finishing.
Re: Bevel
Jerry Nicholson
In my experience, the bevel cutter will raise a burr also. You only use the file to take off the burr, not any visible amount of the laminate. 25-30 years ago I cut my fingers a few times before I figured this out.
Jerry
FredD
Late on a answer Jerry , but as George said , it is a easy and often done task.
The last Plastic job I did , which I never would again, involved moving a school Library to it's new school home and recovering the shelves top and bottom and the dividers and ends both sides. All done in the shop and reassembled on site, it took 14 sheets of plastic ,12 feet long and 5 feet wide and was barely enough.
On your job if your still thinking about it , by all means use solvent base Contact Glue , rather then the water base. I was always partial to WeldWood brand , but several are out there, and work as well.
If your going to use a router to ease the edge which is the easiest way , the bits for that operation that used to be used were beveled in either 7, 15 or 25 degrees.
Using a 45 degree Chamfer bit will more then likely ruin the edge and look funny , even if it doesn't.
I also used a bit designed to cut the plastic 3/16" large in every direction , because of the size of the job and the many same size parts to it.
You won't need that bit , unless your planning on do a lot of Plastic.
My personal favorite is one developed about twenty years ago and I used it on the Library job, is called a "No -File bit" used by all Plastic shops and means it is designed to flush cut and relieve the edge on a slight bevel in one pass.
Piece of cake , no hand filing and you will like the edge.
If you still have the chip to repair and it is fairly large, use Bondo or Rock hard Putty and sand flush, and make sure it is really flush or it will photograph a hump thought the new Plastic.
Lots of luck,
FredD
