We value your privacy.
I just finished jointing many linear feet of cherry (two faces). My big question is where can I find decent push blocks?? Pushing 8/4 cherry through the jointer gets tiring. Yes - my tables are reasonably smooth and waxed.
Here is a picture of my push blocks - and what I just pushed through them.
Are the "Bench Dog Push Bloc"s worth it? I already have a decent push block/stick for my table saw, but it really isn't meant for using on a jointer.
When I use the jointer, I use two types of push block. One is similar to what you have, a block with a rubber pad. The other had a lip on it which I can catch the back end of the board. This allows me to push the wood forward without having to push down so much.
I use both as described by David. The lipped version I use is 18 to 24 inches long, giving me very nice control and leverage against both fence and table. The grip is well above the table to prevent an unhappy marriage of fingers and cutters and a puff of pink spray.
I have found that the best push blocks are grouting trowels that have the foam on them or a modified homemsde version of the same. I also have one that has a wood lip on it for pushing the end of the board. The larger size and handle of these causes less fatique when doing several larger and longer boards.
I have been using the push blocks from Shopsmith for years and love the way they feel in my hands. Since most of the stock I work with starts as rough stock, these make the jointing process more comfortable. Also, since they're bigger and beefier than the normal kind, like in your picture, I think they're safer to use.
I made a 1/2 dozen or so years ago from some plywood scraps. They vary in width from 1/4 to 3/4. They work on the joint and table saw as well. I will post a pic of you like.
I have the same push blocks from Shopsmith for the past 30+years, but I do like George's idea of having one 18-24" long for better control....might just make up one to see how it works out.
After you have a pattern you can bang one of these out in a minute. Make the thickness what you want and the step as much as you need. As you can see at point in time I pushed a piece of 5/8" wide past the saw blade.
1st lumber. Unless you are about to use it for something it is best to leave lumber rough. And what ever gets flattened and edge straightened should best be done after the rough cuttings are made.
2nd pushing devices: Hands are all that is required for edges. For flatening one needs to have something flat to control the orientation of the rough surface against the jointer table and something hooked to push. Best is some pad like arrangement with a hook for pushing. I Use my left hand and a pad like you have for orienting the lumber against the table. a hooked pad would be ideal but I am lazy and just tilt a second pad against the trailing edge of the lumber for pushing. I will get around to making something better some day. Unless you are working up 100 bdft for a kitchen cabinet job these are not onerous things to do by any means at hand.
I was taught that once an adequate amount of the board is across the cutter for both rubber blocks, you never bring your hands back over to the infeed side. Just hand over hand on the outfeed table. A block with a hook will force you back to the infeed, and may rock the board. This is a similar technique that I use with a hand plane. All the pressure on the toe when you start, all the pressure on the heel when you finish. I was given some adhesive back soft open cell foam that I resurface blocks, just like you have, when I wear them out.
... the GRR-Ripper, that is. I have shop-made and commercial push blocks, but for the tablesaw and jointer, to me these were worth the expense. I use two. Even better when used with the MJ Splitter SteelPro. Hartville, Woodcraft and the rest of the usual suspects.
My push blocks and push sticks are just shop made stuff, using up scrap. I will go take a photo if you like, these things are really easy to make. Perhaps this is a holdover from working for a couple shops - that was something I always did to use up scrap plywood, could make a dozen in the time it would take to convince the owner to buy a gripper or whatever.
OTOH, I did buy an aluminum insert plate that takes replacement strips for ZCI or dado inserts. We made ZCI's in the shop, but they always seemed to be swollen in when you needed to take them out .... to each their own I guess.
Mine have hooks, same as the ts stick. For all the worry over jointer technique with a hooked pusher, I've never had a problem with them. As I said, to each their own
I use mine on my Joiner, TS and often on the router table. I have replaced the rails on mine at least twice. I wouldn't be without them as they give me much more control than anything else I have ever used.
I'm with you on using whatever's in the scrap heap and I have several scrap push sticks, many for special purposes, e.g., for thin stock, one with some sandpaper on the bottom and a hook, etc.
However, where the gripper shines like no other is that it has three fences. The middle one adjusts right to left and the outer ones adjust up and down. When I cut really small pieces especially really long ones, I can have two fences comfortably on the outboard side of the blade and one firmly pressing down on the workpiece. Just about impossible to rock the workpiece. And with really long stuff, I use two grippers and piggy back them.
On the hook on the jointer discussion, I was taught that once you have some meat on the outfeed side, that gets the pressure and all you do with the infeed side is to move it forward, not down - perfect for pulling with a hook. I have a sacrificial wooden hook because I slice and joint a lot of laminations. Its always tempting to try to get one more lam out of that board even though its getting perilously thin. Don't want my fingers to be anywhere near that - they do sometimes "explode."
Same technique on the jointing, pressure on the front once there's an inch or so bearing on the outfeed. Pieces shorter than the push block get hand planed
I'm going to have to wander over one day and watch you joint those laminations.... sounds, um... exciting
I suspect those grippers are like the fancy crosscut guides (that I wouldn't do without ), once you have one you wonder why you wasted all that time fooling around with scraps and sleds - though I do still use a sled now and then even though I have the fancy guide.
