Attaching top and bottom.
Gary Smyth
Last summer I mentioned I found a chest on chest on chest on a country road with the topmost chest pretty much destroyed. This fall I began building a new top chest until below freezing weather closed me out of the shop. It now sits with the parts cut and dry fit. I want to move it to a different (warmer) location to start the fit permanently and I�ll do the finishing tasks when the weather breaks. I need thoughts of how to fasten the top and bottom on this chest to the sides. The sides are glued �� poplar approximately 17� x 24�. The side panels fit into long stopped dados on the top and the bottom of the chest. The drawer frames, dust panels sit inside of that. The pics match the way the original was built. While I pondered getting back to this in my armchair I noticed that the old chest�s (probably 1930�s � maybe earlier) bottom side panel had minor splits which I assumed resulted from four each side 1/12 x 6 brass screws inserted from the bottom into the ends of the side panels centered in the dados. The top is different. It used a total of four 1/4� wood dowels glued through the top into the ends of the side panels. My question is this, how do I permanently attach the bottom and the top so that the sides or top won�t split? Can I glue a portion of the dado and tongue of the side (allow the other portion to slide in the dado) and maybe 18 gauge or micro pin a portion from the inside for support � similar to a sliding breadboard edge? Once the back and dust panels are in place I will have additional integrity, but I need the bottom and sides permanently in place now. The bottom and top are dissimilar wood to the sides, poplar and maple. I�m brain dead from overthinking this. I�m looking for a solution.
