bow front update-cock beading
Bill Tindall
While I am waiting for the veneer to stick on drawer #6 I can provide an up date on the cock beading campaign. I am fond of cock beaded drawers. Cock beading covers the exposed edges of a veneer drawer which prevents the veneer from chipping at the edges. It also provides a nice shadow frame around the drawer.
The good news is 5 drawers are beaded, with some difficulty.
This picture illustrates the goal for a bow front drawer. The top and bottom cock bead completely covers the top and bottom drawer edges, while the side cock bead covers the veneer edge, but does not cover the dovetails, adding just a touch of complexity to the fitting.
Shown in this picture is the cock bead that goes on the bottom drawer edge. (In this picture it is reversed end for end to how it will be attached to the drawer, ie. the left end of the cock bead is shown above the right side of the drawer.) It takes me about 1 hour to make this piece, 3 hours to make the first one as I stumbled into the difficulties. There are 6 hand fit surfaces observable.
(1)The back edge of the piece meets the end of the drawer side at some odd angle. I carve this angle by eye with a knife.
(2). The end of the cock bead must perfectly align with the drawer side, again at an odd angle. I temporarily attach the over-length cock bead to the drawer and plane the end of the piece to the plane of the drawer with a low angle plane or chisel.
(3) The length of the miter needs to be scored to provide a target for the miter paring. I use a small knife.
(4) The miter is cut. I use a stick with a 45 degree end as a guide and chisel the miter with paring cuts
(5) The overhang and arc of the bead is marked then shaved, planed and scraped to match the arc of the drawer and the half round bead.
(6) At this point the piece is attached to the drawer with glue and finally the inside arc can be spoke shaved to match the arc of the drawer inside.
Without out some hand tools this piece could not be made. On the other hand, with out some machines I would never have gotten this far either.
