Which glue for bamboo?
Pat Evans
Among my father's possessions, I found this old bamboo model house. It is probably Chinese from his travels there in his youth. Much of it has fallen apart because the glue failed. Because it is so small and intricate, I need a glue that sets quick, but it also must be strong enough to withstand handling. The house is made to be disassembled.
Will hot glue work, or is there a better solution?
Re: Which glue for bamboo?
Hold off for a bit.
Gary Smyth
Are you sure it was meant to be glued? From the pics it looks to me as if it locks together on its own, maybe with the insertion of a pin or catch of some type. I'd say build it complete by hand and use a rubber band, removable tape, or string and see if you can get it whole without glue. Given it's from China and older, this may be a learning tool not a toy.
Portions were meant to be glued
Pat Evans
The house was made to be taken apart in sections, but the sections are made up of pieces glued together. I want to put it back into its original condition and have to repair the sections.
Steve Schoene
I'd think hot hide glue would be ideal. It tacks quickly, but can still be adjusted for some time. It can be used for rubbed joints which need no clamping. It is quite strong, and at the same time it is reversible with hot water. If this is very old at all it's probably what was used originally (or a variant like fish glue)
