OT windshield wiper pump
Doug Ridley
How do you prime the pump on the windshield wipers. I let it go plumb empty and now can't get it to start. Ideas?
Doug Ridley
Re: OT windshield wiper pump
John Veerkamp
Doug,
the pump shouldn't need to be primed. Sounds like maybe the seals may have dried out. If letting fluid sit for a day doesn't do the trick I'd think about a blockage. Try back flushing it. Pull off one of the feed tubes and force some fluid backwards using a spray bottle or water gun.
If your car is outside
Lee Schierer McKean, PA
Sometimes in cold weather rain and or melted snow can enter the spray nozzles and freeze blocking the flow of washer fluid. If your car is parked in a cold area you might need to pour some warm water over the sprays while trying to squirt fluid to get the flow started. Or park the car i a warm place for a hour or so.
Lee
Also
take a straight pin and gently ream out the nozzles. They can sometimes get blocked, not just with ice but with accumulated stuff.
Re: Also
Dale Lenz
I've fixed mine in past vehicle by back blowing air, air compressor, through the line. Have started at the cowling nozzles and worked my way down to the pump.
Good luck
Re: Also
Doug Ridley
Thanks to all. I got it. Discharge was broken and hanging down where I couldn't see it and it was pumping it out on the ground. Finally found it and spliced it and it is working fine. It takes a lot to fix stupid.
Doug
It takes even longer
Bruce, a MN Galoot
to fix what you can't see
