bed slat lumber?
bed slat lumber?
bed slat lumber?
paul in AZ
There must be plenty of bed makers out there.
For slats in a queen size bed, what slat material would you use to support a box frame? I'm trying to sort out various opinions from sources that so far are dubious at best. This is for a bed I'm finishing. Mattress choice is pending but I am wondering about the extra weight of a latex mattress if that is the final choice.
I have read of 3/4" hard maple boards (by ?); 3/4" plywood and even doug fir 2x4s (or 2x6s). I have a supply of some hickory -would that be acceptable?
How many slats? I was thinking 3 to support a box frame rather than multiple slats with no box frame.
Is a center post like a 5th leg necessary to keep a mattress warrantee or to keep the bed from sagging? I think on a king a center stringer with leg is required but on a queen?
TIA.
Re: bed slat lumber?
If you are using box springs, three or more slats would probably work fine. If you aren't using box springs - the more the merrier - I'd space them about every 4" or so.
One of the beds that I made was for a box spring. I used ~7/8" thick maple that was ~4" wide. I had three "slats". There was no middle leg. The slats fit into a "rabbet" in the rabbeted sides so that the slats were even with the rabbet on the sides.
Another bed I made was out of pine and had no box spring. The mattress was supported by pine 1 x 4"s on ledger strips with 3.5" spacers between the slats. That bed is a rustic "country" bed. It was queen sized without a middle leg.
John in NM
With a box spring you don't need many or fancy slats, a few 1x pine on a ledger will work. The box bears the weight, the slats just keep the box from falling off the ledger if there's any slop.
FredD
Why not use the metal frames with wheels , they cost very little and do a better job of support.
Anybody who sells beds or mattresses sell the frames.
FredD
Ryan Hartje
If your ledger is wide enough that the box can't fall through and is well supported, you need no slats (the same as the metal frames). Most recently I used 2" angle iron for the ledger, wanted the box down as far as possible. The queen size needs no center leg.
Thanks guys
paul in AZ
I'm going to go with angle iron box frame support with no slats or center post. The head and foot board posts are not quite wide enough to allow a steel frame support to drop in. I'll add an inch of width if there is a next time.
It may be massive overkill but I have some 3" angle iron to attach to the stretcher rails. Like Ryan i want the box to sit as low as possible to compensate for the new puffy higher profile mattresses so angle iron works out well.
thanks
Re: Thanks guys
FredD
The metal frames are adjustable in width and length , if that helps , sounds like your going to a lot of unnecessary work , but that may just the translation ;-))
FredD
