More on planer exit rollers. (Marks)
Virgil Johnson
It was suggested that the rollers in my planer were in stalled in reverse order or with an in feed roller in the exit position.
Below is a pic from Henry H's planer(competitors machine...thanks Henry) but is identical to mine.The rollers on my planer and Henry's machine are similar in size (within .005") and in both machines the exit rollers are serrated and .035 large in dia. than the in feed. It seems the exit roller is over driven by 2% on both machines. One theory was this overdrive is to keep the lumber from being skewed to the left by the helical in feed roller.
I've searched other wwking web sites and found at least 4 posts of the same exit roller mark problem from similar machines but no posts that identifies the root cause or that has a solution other than backing off the roller to minimize the marks so they will sand out.
As of now I'm waiting on tech support and will post their solution.
