Cheap light bulbs at Lowe's
The local Lowes store is selling CFL "Bright Effects" 60 watt equivalent light bulbs for $1.98 for 6. I bought ten boxes. If you are interested you might check with your local store.
Re: Cheap light bulbs at Lowe's
Galen Vetterick
I've noticed a lot of newspaper ads have shown a real drop in price for CFL but not THAT cheap. If you really get the life out of them they claim 60 should last you a long time or you sure have a bright home and shop!
I have sure had a lot of failures with the ones I have been using. The glass melts through right where it goes into the base. I have even seen posting here on WC and other that show this same failure. Second issue is the solder on the base pin. There is enough heat and maybe some arcing that the contact is lost from solder flow. It does not seem to be realted to any particular lamp or position I have installed them in.
One common factor is all say they are made in China so I wonder if they are just dumping poor quality on the US but in turn is reflected in the lower price.
Good luck with your purchase.
Mistake?
John E in SC
Gotta wonder if that price isn't a mistake. Happened to be going to the local Lowe's at lunch, so I looked while I was there, and their 6 pack of CFL's was I believe $11 and change. Nothing anywhere close to what you found. Good idea to buy a bunch - I'd bet that price won't be the same tomorrow!
Paul Cates - Henderson, KY
You got a deal. I was at Lowe's today as well...I saw the bulbs but not for anywhere near the price you paid.
Re: Question
Not sure. I have been staring at the box for a while and what I got is they take 13 watts to produce about 60 watts output.they claim 10,000 hours of operation, 825 lumens at 2700 K (soft white). They claim a 60 watt incandescent bulb puts out 840 lumens.
Jason Roehl in Lafayette, IN
Re: Question
Okay...the 2700K is the color temperature. Lower is "warmer" (figure that one out!).
CRI is the acronym for "Color Rendering Index". Natural sunlight is 100. A very good bulb might be 80-90. Excellent would be 95+. Cheap bulbs might be near 40-50, and make the colors on your walls goofy.
Jason
This is the second time they have had them. Bought a case about two weeks ago. They appeared to be a closeout special on one of the end caps. My son spotted them and we were discussing $1.98 a What? Each bulb or the whole box of six? A nearby clerk spoke up and said it was the whole box, and that she had bought some herself. We bought ten boxes because were were outfitting my son's house.
Went back to get more for friends and they had sold out.
Today we saw them again. I talked to a clerk and he said they were just a special purchase and were not a close out or dead end technology or seconds. So, I bought a second case. About $21 for 60 bulbs was too good to pass up.
The number under the bar code is 7 21365 60039. I am not sure, but I don't think the 7 counts.
