We value your privacy.
I was hoping some one might have seen an article on or knows how to build a jig to construct the louvers into a cedar rectangle frame. I have a lot of nice cedar stock to build them myself, and pricing the vents online they are very pricey. Any help would be much appreciated.
Ed, Norm Abram had a show a few yrs ago which showed how they make the louvered blinds and gable vents. Maybe you could contact the New Yankee office to see if they might be able to set you on the right path.
Ed, I have made a bunch of attic louvers over the years. I cut the slots for the louvers with a radial arm saw. Just pick a fairly steep angle lake about 30 degrees and cut the slots. Lay the first one out carefully and cut the slots spaced as accurately as you can. Reverse the angle to cut the second one. Mark it off from the first one and cut it carefully. when you rip the slats, you will have to rip the same angle on the edges. The sill piece has to have "ears" on it to accommodate the facing or brick molding. the angle for these as to be fairly steep or the wind will blow rain and snow up through the louvers. Also the space between the louvers needs to be less than an inch, maybe 3/4" to keep the birds and bats out and to keep squirrels from slipping or gnawing through.
It would be easy to set up a template to do this with a router. Just be careful to set it up so that there is no repeated error. If the spacing creeps off even a 1/32" each time, you louver will end up looking like fan.
The commercially made louvers I see around here have hardware cloth stapled to the inside, to keep out small critters. Mice can get through incredibly small spaces. 1/4" mesh should do it.
You are correct. I guess I thought that screening the inside went without saying. 1/4" hardware cloth is tougher than window screen, but might not keep wasps out.
The OP did not ask about sizing, but it is important to realize the louvers generally reduce the opening by about fifty percent. That is, only the slots count as ventilation, not the whole thing. And Screening reduces the effective area by another fifty percent. So, if you are wanting one square foot of net free vent area, you have to build a vent that has about four square feet total.
