HiPURformer and Refacing ??
Joe Burke
I searched the archives for post on Franklin's HiPURformer hot glue system and it sounds like a pretty good product.
Specifically, I have a refacing job looming and I wonder if anyone can give some input about the system in this application.
I'll be using 1/8" luan plywood covered with cherry veneer to reface the face frames, and this is where I'm wondering if the Franklin system might work well. I have no doubt that the product will bond, but how thick is it? Will it be viscous enough to spread out while hot and yield a fairly tight joint? I'm thinking it would be ideal to apply the slower setting adhesive and use spring clamps to apply the required pressure for a couple of minutes while the glue sets.
I'm certain I can find a multitude of uses for the system around the shop, but I'm thinking it might really excel in this application.
Thoughts and input would be appreciated.
Re: HiPURformer and Refacing ??
Dave Paine
I have this product, although I have not used for some time. Likely the glue may now be old and dried out.
The glue is very expensive. It is viscous, and this has been my problem. In some cases it is too viscous and I fight to get the joint to be as tight fitting as desired before the working time runs out, meaning the glue starts to harden.
If you want to glue some kind of face frame, I think you will struggle to get the glue to level out evenly before the temperature drops and gets too viscous.
These days I use Titebond III only because I wanted potential for longer setup, slightly thicker to apply and only wanted to inventory one product. Titebond II would also work for this project.
