ot adding water heater
Jerry Gibbs
have a trailer in FL with a 20 gal water heater. Replacing it with a larger unit has a lot of issues. can i just add another 20 gal heater and plumb them in series?
Jerry Gibbs
Re: ot adding water heater
Bill Turpin in WNC mountains
A lot of trailer heaters are 115volt. The electrical circuit ampacity may not allow for two elements.
have enough amps
Jerry Gibbs
question is can i have two heaters on the same water line?
Re: have enough amps
Jesper, Denmark
You can have two heaters, but in parallel, not in series. It will require some intelligent plumbing - such as using one heater for some outlets and the other for different ones.
Replacing the one yu have with an instant hot water type may be a better solution.
Justin Szeliga
You can plumb them in series, there should be no problem at all. Water in each will be heated, you open the tap & water flows out from the 2nd tank, then the hot water from the first will enter the 2nd giving you double the capacity.
I can't see any problem at all.
curious....
John in NM
why not series? Mom's house has some solar panels upstream of the heater, effectively the same thing, though the goal was different. If he wants 40 gallons of hot water available, it seems like this would do it.
Instant hot water
paul in AZ
Great idea Jesper.
Instant on demand hot water heaters are wonderful. I had one on my last boat -not here of course, it was ocean sailing.
Propane heated from a regular 5 gallon BBQ tank, w/electric igniter off the 12 volt system. All lighter, more efficient than a big ol' hot water heater tank. They just fire up when you turn on the hot water and shut down when you are finished.
found an answer
Jerry Gibbs
found a plumbing retailer site which says there is no problem connecting the two heaters in series. they recommend it if you cannot replace the existing tank with a larger unit. if the first tank is set lower, the second tank is raising the temp less than the normal feed temp, similiar to the up-line solar tank referred to earlier. both tanks are getting used extending the life of both.
Re: found an answer
I think you have found the correct answer. Hook them in series. Be sure both have TPR valves (Temperature and Pressure Relief). The first in the line will preheat the water for the second. It might be wise to be sure they are both set to the same temp or that the first one is slightly lower than the second. And be sure the second one has the "heat traps" in the lines to prevent thermosyphoning. You could also insulate them and insulate the first few feet of both the hot and cold lines. A pan under them with a drain is a good idea also.
My house is done that way.
John E in SC
I have 2-40 gallon water heaters plumbed in series (outlet of one is inlet for the next) in my house. We have 3 kids, and that's what the plumber recommended. It has worked well for 8 years so far. (And my 15 year old daughter can STILL use all the hot water with one shower!)
