Not OT - water "catastrophe"...
I had the riser on my outdoor faucet split today. I noticed it because I was in my basement shop and a stream of water came spewing out of the corner.
NOT nice. Anyway, the riser is replaced and the mess is mostly cleaned up. Evidently the gravel bed under the garage floor filled with water or the water traveled around the house on the sill plate on top of the cinder block walls.
Whichever way it did it, it came through the wall in a crack in the corner. I would like to fill this crack. Any suggestions as to what to use? The walls are painted cinder block.
Re: Not OT - water "catastrophe"...
Re: Not OT - water "catastrophe"... *LINK*
Stuart Johnson
If I understand the problem I think the product you want is hydraulic cement.
hydraulic cement
Justin Szeliga
The hydraulic cement will do it, much easier if the water has stopped, mix it with ICE (no foolin'!) cold water to slow the set. Force it into the crack & trowel off to keep pushing it in as it sets & expands slightly. WEAR HEAVY RUBBER OR VINYL GLOVES or it will eat the skin off your hands.
But I just hate to buy such a large amount...
Well - $7 for 10 lbs. I was thinking caulk or sealant. Should I chisel the crack out?
TIA
Re: But I just hate to buy such a large amount...
Stuart Johnson
I've never had to use it but I don't think it would hurt to chisel out the crack a bit. If you do be sure to undercut it a bit to help hold the cement.
Justin Szeliga
The hydraulic cement expands as it sets. The hole needs to have a shape that will key the cement in. It's probably a better solution than a caulk or sealant, but if you've a crack in masonry it will always be a problem.
