REAL MILK PAINT
O.T. Removing a Rivet
Stuart Johnson
My wife bought a new purse that has a strap with a loop that she thought was a snap. Instead it is riveted. She wants me to take out the rivet. It doesn't look like I can drill it without destroying the strap. Any suggestions on how it can be removed?
Re: O.T. Removing a Rivet
Side cutters
Dustmaker Mike
how far does it stick out? Can you get some side cutters on it and just cut the head off? Is there a center hole where you could start a drill bit? If so use a drill bit in a chuck and turn it by hand.
Easy stuff . . .
steve mackay
Take your Dremel (or file) and grind off one side. The Dremel works better with a smaller burr. Won't heat up too bad either. Then just pop it out.
Re: Easy stuff . . .
Ditto on the dremel. I used to do leather work and have tried to drill out one end. The rivet spins. If you can get needle nose vise grips on the big end you can drill out the other side. If you can't then a Dremel with a small stone will grind off the flange and let you pull the rivet out.
Topic change now..  how to replace purse strap?
Stuart Johnson
I guess that pretty well says it :( I thought the side cutters sounded good, they would be thick enough to push the strap apart and get to the rivet. They worked just fine right up to putting on little cutting pressure. The rivet cut right along with a nice wedge of strap. Thanks for the ideas but after I got the rivet out of the good part of the strap the hole made for it was too big for the strap to be used. So I'll replace the strap or convince her a clutch is more fashionable.
