Is this sander fixable?
A.J. Hamler
A.J. Hamler
I have a Delta combo sander -- 10" disc and 6x48 belt. I've used for years and never noticed anything wrong with it, but just discovered that the belt�s table isn�t coplanar; for lack of a better description, there�s a slight "twist" in it.
I don't typically need or use it for truing-up projects, but I did a box with some rough rabbets on the bottom that I wanted to level quickly before hand-sanding and used the belt. It was just a quick sanding but when I set the box on my worktable it wobbled. I thought maybe I used too much pressure on one corner while sanding and tried again, more carefully, but there was no change.
I tested the belt with a small 2�-thick chunk of oak that I first checked for square -- it sat perfectly solid and level on my table saw. A few seconds on that belt sander that previously flat block of oak wobbled like a rocking chair.
Now, I've fiddled a bit with the tension on the belt tracking but that seems to make no difference -- that belt table (or platen, I guess it is) simply isn't coplanar. Is there any way to fix this? I've done some Googling on it and have come up dry.
I'm clueless. Does anyone know a fix for this, or is it time to go shopping for a new combo sander?
A.J.
Re: Is this sander fixable?
If it's that bad...
... take it to a machine shop and have it surface ground or milled flat. Shouldn't cost much.
Bill Howatt
I am interested in hearing the replies. I have an off-shore one but have never considered it more than a rough, non-precise sanding device.
Bill
Re: If it's that bad... *LINK*
Phil Joines
Is it possible one or both of the rollers are misaligned?
If it's like mine there isn't enough material to mill, it's just heavy sheet.
There may be some way to twist it flat buy I wouldn't be hopeful.
The part list for mine (31-695) calls it the "frame" reference #38, part #1346372.
Ereplacementparts sell it for $42.
http://www.ereplacementparts.com/delta-31695-type-sander-parts-c-3275_3512_3563.html
A.J. Hamler
Yep
A.J. Hamler
Yeah, that's it exactly. It's sheet, and not enough to mill down.
Can you get it off. If you can you can get the twist out. Here's how I did one of the cast iron table extensions for my table saw. I place it on blocks on my workbench. I cut the block that was under the high corner shorter. Then I put a 2x4 between the ceiling joist and my table leaving enough room to put a small hydraulic jack between the 2x4 and table. I jacked it down to the block and let it spring back. Check it. Removed more material from block and do it again. After about 4 or 5 cuts and what seemed like way too much bending it came back up and the surface was true. I did have to hold down the opposite corner with some weights and my body while cranking but it did work.
I assume yours will be much easier to bend. You might have to put shims under it when reinstalling if it doesn't sit flat on that surface.
Joe Mohnike
Live with it. In my opinion, which is not worth much, belt sanders, like mentioned are for rough work. The rollers are crowned, which creates different pressure on the belt tight in the center and loose on the edges, this alone will cause uneven sanding. As the belt gets used the grit in the center starts to disappear leaving more on the edges which only compounds the problem. If you have used it for years and has worked for you, keep useing it.
My opinion only.
Joe M.
Dave Bair, Eaton Rapids, MI
On my JET version of this sander, the table pivots so that you can vary the table-to-platen angle. I can adjust each side of the table with separate, adjustable stops on each of it's pivot points. Do you have anything like this on your machine?
Agree with Bill
Galen Vetterick
In fact it never entered my head to think it would sand things FLAT since it is also impossible for me to put uniform pressure on a piece on a moving belt. Smooth but not flat. Just my little Delta combo that I have had for years.
need more data
Bill Tindall
The definitive experiment, not reported, is to put something known to be flat on the platen of this sander and see if it indeed is flat or not. The experiment you did is not convincing that the cast iron is at fault.
In any case, the task at hand would be accomplished with a hand plane in many shops. They are a wonderful device if you have yet to discover their merits. On the other hand they are useless boat anchors unless properly sharpened.
Re: Is this sander fixable? *LINK*
Steve in Phoenix
I agree with Bill. I am a dedicated electric guy, but handplanes have been a lifesaver. I returned a Grizzly Oscillating Edge Sander due to a twisted platen. Not an easy task, by the way (physically, I mean. Learned a lesson about levers on that one). Grizzly did inspect other units, and found it to be a common issue. I think I fooled myself into thinking the sander was something it wasn't due to the width of the belt, and the fact it could flip to a horizontal position.
My understanding now is that these are truly edge sanders only. Great for templates and outside curves. I find myself needing one now as I am currently using a belt sander clamped to the workbench.
If I were you, I would keep what you have, and get a jack plane and a block plane for the times when an electric tool can't do the job
Call Walt over at Brass City for some good old tools 203-574-7805
Brass City
A.J. Hamler
Thanks, all!
A.J. Hamler
Thanks for the help and suggestions.
Since most of the use the belt portion of the sander is for rough sanding only, I'll probably just keep using it as I have been -- no telling how long it's been like that and I only noticed when I sanded the bottom of something. All my final sanding is done by hand, so I'll just keep using it but keep its flaw in mind.
It's the disc I use the most on the combo sander anyway, and it's just fine.
