Hand Crank Drills
Tony - Memphis
I'd like to buy an old one. Just starting my research. Any tips? What to buy or not to buy? I like the Millers Falls #2 drills. This is for using in my shop, I'm not a collector.
Thanks,
Tony
Hand Crank Drills
Tony - Memphis
Thanks,
Tony
Re: Hand Crank Drills
Ken Oakley-Sunny St. Cloud, Fla
Look on Ebay--Millers Fall made quality products.
Only one rule to follow
Bill Tindall
I have some and use them all the time for drilling pilot holes for brads and screws. I use three for hardwood trim carpentry work, one for each size nail used- 6, 4 and brad. They provide precise drilling control for pilot holes and handle drills for even tiny brads (you will need a set of number drills to go with the drills). I find the big ones useless for drilling larger holes(perhaps my shortcomings). Any kind that has two small gears driving the spindle work fine but some are more clumsy than others. The single small gear variety can be sloppy and not smooth acting (no doubt exceptions to this rule)
Of the 7 I have a Millers Falls 77 is the one I reach for most often. It has nice balance and works smoothly. As we speak it has a 0.040 inch drill in it making brad pilot holes in cock bead.
Moses Yoder
You might post this question over on the hand tool forum. Yankee made a nice drill with a neat little transmission in it that would turn the drill clockwise whether the handle was cranked forward or backward. They made several sizes, the small size is my favorite drill. I don't remember for sure what number it is but I think it is a 1530. The hand tool guys would know, my memory is bad due to meds I am on. If you are only going to have 1 drill this would be the one to have.
Joe Mohnike
I have several, which I purchased at yard sales, etc. The first thing I check is the chuck, make sure all the parts are there, and that there is minimal side to side play in the chuck and frame. It's about time the world woke up to the cordless drill, I also have a cordless saw;-).
Yes, it's the 1530
A great drill, optimal for bits up to about 3/16", a tad small for bits larger than that.
A lot depends on what your intended use is. The Millers-Falls No. 2 is a large-frame drill with a large chuck. If you plan to use your drill for the screw holes for hardware (hinges, latches, like that), a smaller drill would be better. If that's your intended purpose, you might consider a push drill, too (in which case look for a North Bros. or Stanley "Yankee" push drill - the bits for other makes are hard to come by); push drills will fit in tighter spots in a cabinet.
Another nice drill, not as well known but especially great if you have young kids (either permanently or on visits) who want to use the tools, is the Stanley 610, which has fully shielded gears (to keep little arms and fingers out of the works), and which also has thrust bearings that make it a very smooth operator.
Nothing wrong with the M-F No. 2, as long as you get one with solidly attached handles - floppy rear handles is one of the weak spots in the design. It's just kind of big for many applications.
