Tenon musings
Tenon musings
Tenon musings
I typically use loose tenons. I can set up my plunge router and cut mortise rather easily. When I use loose tenons, I typically make my mortises either 1/4" or 3/8" wide by a "reasonable" "height" depending on the apron size.
So - I figure for a 1 3/4" x 1 3/4" cross piece and a similar size leg, I should have a tenon that is ~1/2", right? That shouldn't matter if I have a loose tenon or a regular tenon.
So what would be a reasonable "height" for the tenon on that size piece of lumber? I won't got into what would be a reasonable length of tenon - I figure that will be whatever the traffic will bear (~1 1/4 - 1 1/2" in each side).
Thoughts? Opinions?
TIA
Re: Tenon musings
Double tenons *LINK*
If I read you correctly, you're talking about a table base made of 1 3/4" square legs and rails? If so, I'd use dual 3/8" x 1" (in section) tenons, spaced down 3/8" from the top of the legs.
Just my 2�,
Similar situation
Re: Tenon musings
Thanks.
That's answers the question quite nicely.
Re: Tenon musings
Like this?
Bruce, a MN Galoot
I used a router to cut the mortises with the wood held in my usual router jig (a la Tage Frid's books). I don't have a hollow chisel mortiser - maybe someday. The tenons were cut on a table saw with a tenon jig. Maybe I could have done it by hand, but not with as many as I needed to cut for the cabinet - 8 sets. Both the rails and legs were 1.5" square.
