Water Lead (OT)
Water Lead (OT)
Water Lead (OT)
larry in kansas
As it says I have a water leak in the water line coming into the house very small. I have a rubber patch and hose clamps around it for the time being. I know that I`ll probably be replacing the whole line from the meter next summer, but for now if this doesn`t hold, I heard about some tape that you can wrap around it with full pressure and it`ll seal it. Of course I don`t know where I saw it. Can anyone tell me. TIA Larry
Re: Water Lead (OT)
Don't know about the tape
but your hardware store sells a fancy version of the rubber and hose clamps, about 4-5 inches long (depending on diameter of the pipe) that will serve for quite a while. Ask about a "pipe clamp," and explain what it's for (the trouble is, "pipe clamp" has multiple meanings).
My old employer (public university) had one (large, like 3-4" diameter) pipe that was said to be end to end pipe clamps.
Re: Water Lead (OT)
Clint Searl
Re: Water Lead (OT)
Clint Searl
If you can relieve the pressure for a little while, a gob of plumbers epoxy over the leak may do the trick. Clean the line around the leak. It worked for me.
Clint
Re: Water Lead (OT)
Re: Water Lead (OT)
John Veerkamp
Many hardware stores carry "extreme Tape". It is supposed to be able to withstand normal water pressure including hot water pipes. I've never personally tried it, but sold a bunch.
There are also water line patches that are a glorified version of inner tube and hose clamps. Two pieces of curved metal with four ears on each, a piece of neoprene and four screws and nuts to hold it all together. This will get you thru till summer unless the whole pipe is rotten, then all bets are off.
Re: Water Lead (OT)
Re: Water Lead (OT)
Stuart Hough
Larry,
There is a self-sealing silicone "tape" out on the market that will do as you need. If your local mall has a "As Seen On TV" store, they will have it. I have used this stuff once before and it does work, although I can't testify as to how long it will be effective. I used it on a radiator hose and it held up for the week until I could get the proper hose on special order. I would think that if it held up under automotive pressure and heat it should last for a lot longer as a homeowner repair. Good luck!
Re: Water Lead (OT)
Re: Water Lead (OT)
Bill Tindall
I think Lee Valley has it. Many catalogs do. It is called "silicone tape". I can't imagine anything better than a clamp over some rubber gasket-like material. I patch irrigation hose that way and it lasts as long as the hose.
Re: Water Lead (OT)
Re: Water Lead (OT)
Tony - Memphis
I get it at AutoZone.
Tony
