Re: Question on project to do lists...
AZ in Colorado Springs
I've observed a couple of things over the past few years as I'm building more larger projects (larger in this case meaning not physically larger, but requiring more than just the few parts that go into a book case or set of shelves) than I have in the past.
Drawing the pieces helps to avoid mistakes in accounting for joinery (like adding length for one tenon but forgetting the other end, or that all four corners overlap in dovetail joints). I don't use computer programs for sketching, just good ol' graph paper.
Making a parts list helps in identifying all the pieces that will be planed or ripped to similar dimensions -- helpful not only in minimizing machine set-ups, but in repeating the same dimension, if that is important. (About nine months ago I was working on a project that required 20 crib fronts -- a rail/stile frame with dowels used for the spindles. We deicded to use 1x2 poplar for the frames, joined with stopped dovetails. The BORG 1x2s were different thicknesses, making the milling of the dovetail joints much more tedious than expected -- and there were 80 corners to be joined!)
Likewise, making a "to-do" list helps to organize the work efficiently, as in cutting the mortises of a cabriole leg while the leg blank is still square. I find that putting the steps on paper helps me to think through the process more completely. It also helps me to visualize less obvious potential "log jams".
For example, I'm currently building toy box, and it is a combination of a couple of projects plans I've built from Popular Woodworking -- Roy Underhill's tool chest and a blanket chest. There are a couple of interior compartments where finishing would be impossible after the pieces are assembled. It's easier to spot such problem areas, and plan ahead for them, if I outline the work plan. I like to do that using MS Word. Much easier (and neater) to edit and insert steps (and add notes after the project is completed, for the next time 'round) than a hand written list.
It also provides a place to record what the finishing was -- shade of stain, etc, if you need that information later.
While it probably is possible to spend too much time organizing, I'd guess it's a lot more common to spend too little time organizing a project. Of course, the more experience you have, the more you have in your head and don't need to put on paper. It's less visible to others, but no less organized.
Just my thoughts ...
