Aggravation game with daughter
Lee Schierer McKean, PA
My daughter came home across the New Year holiday and stayed this past week. Prior to her visit she asked about making a game board with Chinese checkers on one side and the marble aggravation game on the other with a place to store the marbles and dice. After looking at a lot of designs on the internet and developing cad layouts for the two game hole patterns, I designed a two sided game board with an internal marble storage area. We built this together this past week. I did most of the woodworking and she did the painting and finishing. She drilled most of the marble holes. My drill press didn't have enough throat depth to reach the interior holes so I had to devise a drill stop for the countersink bit we were using that would exactly match the depth of the outside holes on the remaining interior holes. The door on one side opens to allow you to get out or put back the marbles. It is held closed with two embedded rare earth magnets. It was a fun project. If you plan to build one of these purchase your marbles first. DAMHIKT.
Thanks for viewing
Lee
Re: Aggravation game with daughter
Very Nice!
AZ in Colorado Springs
Nicely done.  How about a timeline.
Gary Smyth
Also I'd like to know more about the stop set up and the painting. What did you do to avoid tearout. I have a 3/8 box core bit in a different but similar situation and it is beating me to death with tearout. It is a new bit so maybe it's speed -- whatever it is it's not working --did you build a template for the top or cover the top? The paint looks silk screened. How many clear coats before paint?
Re: Nicely done.  How about a timeline.
I did the hole pattern layout on Autocad and printed the layout on paper. I taped the paper to the top of the wood hexagons and used the centers to drill the holes. I used a drill press on the second slowest speed setting and a countersink bit. I set the depth stop so that The tip would just start to deform the inside layer of the plywood, but not make a hole. I used Rockler 39578 Solid Brass Small-Box Cylinder Hinges for the door and two 1/4 x 1/4 rare earth magnets. I made the entire frame and left one corner where the door would be un-glued. I used a band clamp to hold everything in place during glue up. Once all the other joints were dry, I cut out the door section with my TS and made a new door piece to exactly fit to eliminate the kerf. There is also a spacer in the center so the plywood wouldn't bow in and trap the marbles.
The assembled frame and sides were coated with one one coat of clear shellac to fill the pores and prevent paint creep. We used masking tape to outline the painted areas and painted each color by hand. Once the enamel paint was dry we coated the entire piece with two coats of MinWax water based Poly Acrylic. We completed the entire project in 3-4 days including time for the paint to dry.
Lee
