Cradle designs?
Cradle designs?
Cradle designs?
Todd
Hey everyone,
I find myself in the position to need to build a couple cradles in the next couple months. One for a friend, the other to keep. I've seen some shop shots posts of cradles, and I've always had good luck here on the boards. So if you've built a cradle, post the pics for me! Thanks!
Re: Cradle designs?
Re: Cradle designs?
Joseph Mulherin, Sr
Hi, Todd, if the past years I have built five of them for family. I bought the plans for them from: www.furnituredesigns.com. They are located in Illinois.
Re: Cradle designs?
Re: Cradle designs?
Here's a cradle w/ cradle stand.
The design is my own - I still have working copies of my notes if it appeals to you.
I made this one so that the stand could be disassembled.
I highly recommend starting from the cradle mattress or pad - this one is sized for an 18 x 36". You can get the cradle mattress/pad as well as sheets and protectors.
Re: Cradle designs?
Re: Cradle designs?
paul woolson
JL, I'd be interested in seeing any notes/measurements you might have. I'm available at
paul at woolsonsoundcraft.com
Re: Cradle designs?
Re: Cradle design
Gary Smyth
I've written about this before but it's worth repeating. Whatever design you choose make certain the cradle moves side to side not front to back. The web offers some data but quickly, a front to back tilted movement for an infant has been associated/linked/related (please check it out as I changed computers and I can't find the link) with infant fatalities. Typing in "infant death and cradles" will get additional information and links. Also build in a locking pin to freeze the cradle in a flat "crib" position. Don't mean to scare, just make you aware.
Re: Cradle designs?
Re: Cradle designs?
George Colonel's Workshop-Havertown PA
Hello Todd,
These are the last two that I have done, both are in cherry. I've built others which are more in line with the floor rocker depicted here. This iteration features box jointed construction. The sides, front and back are milled to 1/2" thickness which is a bit more refined than Norm's 3/4" version, at least to my taste. I left the rockers at 3/4" thickness and made the rocker ends into rounds which prevent over tipping and accidents to big brothers and big sisters who play at that level in that vicinity. :) Both examples achieved the deep cherry coloration as shown in the floor cradle.
George
Re: Cradle designs?
Re: Cradle designs?
Steve Schoene
Note that there are some relatively new safety rules for cradles. both Canadian and US. What I remember from the canadian, mattressses must be rather thin, and there is a minimum height to the sides above the mattress as well as a limit of 20� for the maximum rock. No opening is to allow passage of a block 100 x 100x60 millmeters. You should be able to find the Canadian rule on line, but when I looked for the US rules the regulation referended an ASTM standard, and they charge for those.
