We value your privacy.
The best way is with a drill press - but few people have a drill press that large or a shop ceiling that tall. Though if you had a bench top drill press....
Seriously though - alignment is everything. I would take a cut-off piece the same size and drill a 1/4" hole through it with a drill press - this is your alignment piece. I would clamp your long piece and the short alignment piece to a bench and drill away. I would also have a level on your drill to make sure that you were level. I'd also recruit a "spotter" who would tell you if you were not level.
The other way that I do similar things is with bevel gauges and mirrors. I have some small mirrors that I use for alignment along with bevel gauges.
I clamp one end in a vise and use levels with a long bit to align the drill. I use spade bits with an extension. They seem to drill into end grain better when using a hand drill.
Know anyone with a Shopsmith. It is an ideal machine for this. Just clamp the wood to the table. You can use the miter gauge to align it before clamping. Use the extension table to help support it. My Dad and I did this on his during Christmas.
Take an off cut and drill through long grain with the bit to be used, this is your jig that will guide the bit. Clamp the jig to a flat surface then clamp work piece to same surface with hole aligned butting end grain against the jig. Drill away.
The idea is to make a "bushing" out of a scrap of wood the same size as the cross-section of the piece you want to drill. Use a drill press to make sure the bushing hole is exactly square to the bushing piece. Then screw it to a piece of plywood, clamp it to the end of your board and drill with an aircraft bit and a hand drill.
If you want to borrow mine, let me know. For the cost of shipping you're welcome to use it. I have a Dowl-it Model 1000 which seems like a perfect solution.
Is this something you will be doing repeatedly or more of a one-off requirement? For a one-off it would seem pointless to build a fancy jig. I'd be inclined to clamp the stock in a convenient position, mark a guide line to aid alignment, drill a small shallow indentation in the stock to prevent wandering, then drill away using a super-sharp parabolic bit and a level on the drill to keep the hole level.
I haven't seen this mentioned yet but there is a frequent problem when drilling into end grain. A standard pointed drill bit will want to wander off line with any change in the grain direction of the wood being drilled. The way to minimize or eliminate this tendency is to use a brad point bit. Brad point bits generally will not wander.
I would use my RAS with a chuck attaches to the non-blade shaft end. But, not everyone has a RAS. The simple jig that Ellis proposes will work fine but you need to buy a long brad point bit.
Howard, I have read just the opposite, that a standard pointed drill bit is better for end grain. Hopefully others will offer their experience on this subject.
A group of woodworkers who invariably drill end-grain and have to do so very precisely are the penmakers. All that I've known seem to use parabolic bits and every maker of pen hardware seem to recommend them (and sell them at high prices). I have tried it with standard twist drills and with at least two different sorts of brad-point bits (cheapies and expensive Fisch long-spur) and with parabolics and the latter have given me the best results, hands-down.
I have drilled parallel holes to the work piece with a hand drill by, 1st drilling a test hole into a hardwood block (guide block 2" thick min.). Then I would clamp a board to the bottom of your board, possibly using a spacer to get the distance from the surface of the board to the hole location. You do not even clamp the guide block to the board. I just center punch the end of the board to scribe lines. Then I just touch the mark spot with a small drill. I use the guide block, drill bit had drill to locate the location and drill. You might have to do this in 2 drill bit size steps, too improve the drill bit location.
I don't know how accurate you have to be. Good luck
