O.To.-Tractor with snowblower?
Thomas Norton
I am starting to thinking about a new yard tractor that will alos handle a snowe blower. Anyone of you guys have this kind of set-up? What brand?
Thanks
Thomas Norton
Thanks
Re: O.To.-Tractor with snowblower?
Dave Paine
From 1983 to 1998 I had a used Gravely 16HP lawn tractor. Likely originally an early 70's model. Used to put on snowblower for winter. My only issue was the unit was manual lift. Eventually got to be too much for the old back.
Eventually got a used John Deere 755 Utility tractor in 1998 with 19HP diesel, bucket and plow. I never use the plow. Still using this unit. Only 1 maintenance trip to the dealer this summer and replacement of the starter motor. Also has 60in mower deck for the moving duties.
My neighbor has an Allis Chalmers. Older than my Gravely.
I can recommend some features of a desired unit.
a) Hydraulic or some motorized lift. The blower will weigh several hundred pounds and hang out some distance from whatever mounting point. This is a LOT of turning moment to overcome. Now that I have hydraulic, I see the ease of use and lack of maintenance.
b) Shaft drive from tractor to the blower. Last thing you want in the middle of clearing up after a storm is for a belt to break.
c) Try to get one which can handle a blower which is the width of the outside dimensions of the largest wheels, typically the rear. My Gravely was just a few inches narrower on the blower and in very deep snow, this would mean more work since I could not clear a complete path for the tractor. My JD bucket is as wide as my rear tyres.
d) Highly recommend 4 wheel drive. The Gravely was only 2 wheel drive. Easy to get stuck and the dead weight of the blower meant it did not like to turn with the front wheels. The JD is 4 wheel drive and so far have not seen the need for snow chains. On the Gravely it was a must.
e) Get the largest unit and wheels you can afford. The old Gravely rear wheels are the same size as the front wheels of my JD which has 46in rear wheels. Gives many inch extra clearance for the deep snow.
There are times I would like a blower, such as the 3ft + snow we had last March, but for the normal few inches to feet of snow I like the bucket to allow me to pick up the snow and pile it in select areas.
Another benefit of a bucket is that the snow does not get blown back in my face. I can remember times when I had to face the Gravely chute into the wind to avoid hitting the house/windows with the snow. Never fun when the wind blows this straight back into the face.
Lots of good brands. Not sure how many models are still made in US. I expect generally get better quality with more expensive brands. Consider tractor dealers. They normally have high end models which are not sold through the big box stores.
Look for cast / forged axles rather than stamped steel. Also compare thickness of the overall frame and body panels.
I live in the boonies so no street lights. I wanted a unit with good lights. I can also add extra lights on my Roll Over Protection rack.
Kubota *LINK*
Jim in River Oaks, Ont.
My Uncle uses a Kubota at his farm for snow clearing, his is equipped with a snowblower and front scraper. He's 80 so if he can use it any young pup can,
Take care,
Jim
Kubota
Dave Bair, Eaton Rapids, MI
I ran a tractor-powered blower for about 20 years and hated it most of time. I had a Sears 18 hp tractor and a shaft-drive Sears 48" blower. It was a pain to put it on the tractor every fall (it weighed at least 200 lbs. and required the lining-up of 4 hitch points), it was difficult to maneuver, used a lot of fuel (2 gallons/plow), was difficult to store in snow-ready configuration, always managed to cover me in fine-powdered snow despite a movable chute (you're seated about 2" higher than the discharge chute). It was better than the dozer blade I used to use, but that was about it.
I now use a dedicated 30", 9hp walk behind blower. It takes no setup beyond putting in gas, it turns on a dime, plows the drive at least twice on a gallon of gas, is easy to store right in the garage where plowing actually starts, and keeps my upper body out of most of the blow-back snow. Alas, it is also a Sears and has it's own set of problems: the handle configuration and fail-safe interlocks can really test my arthritic thumbs and the death grip you need to maintain on the handles can result in cold hands if you compress the insulation in your mits too much.
Grant in Iowa
Thomas,
Give us some more information so we can make recommendations that better fit your needs and budget.
-How large is the area you clear snow from?
-Where do you live?
-How much do you mow?
-Would a loader be useful? How about rear implements such as a tiller, blade, etc?
-General budget?
-Do you prefer the "get you by" approach, or the "buy it once and use it for life" approach?
I currently own a Kubota BX2200 4WD with a loader, tiller, blade, mower deck, etc. which I picked up used about two years ago. One of the best things I have ever purchased, this machine turned what used to be a lot of work into play time. Check out tractorhouse.com if you are interested in compact utility tractors.
Regards,
Grant in Iowa
That looks like SO MUCH fun!
Bruce, a MN Galoot
mdclor
When we lived in Upstate NY, between Rochester and Buffalo, I had a JD 1050, which is a 3 cyl diesel 4WD tractor with a 5 foot bucket. I laughed in the face of snow.
It would move all the snow in front of it and never got stuck though I tried sometimes. It is probably much more tractor than is needed for JUST snow removal, but they make 2-3 smaller models and a loader is always handy.
FWIW,
Merle
Paul Blackwell
I have a eighteen horse Cub Cadet which is now about 20 years old. It had a 50" mower deck and 48" snowblower. I recently bought a Cub Cadet zero turn radius mower, but kept the old tractor with snow blower to clear the driveway. Mine has a 48" blower which is a few inches wider than the wheels. Repairs have been minimal, and it will blow anything you can put through the auger. I had to put wheel weights and chains on the rear, plus I had 100 lbs of steel plates mounted to the hitch. Biggest problem is a prevailing west wind which blows the snow back in your face unless you can get down to the road and work back toward the house.
Thomas Norton
Paul,
I had a Cub maybe 30 years ago and it work great. Though I have heard that the quality today is just not there. What do you think?
Paul Blackwell
"Is the quality of Cub Cadet as good as it used to be?"
I've had my ZTR Cub Cadet mower for two seasons so far, and I've found it to be a great machine. My grandson mows the lawn most of the time, and he cut mowing time from about 3 hours using the old Cub Cadet with 50" deck to one hour and forty-five minutes with the 48" ZTR. We mow about three acres. He credits reducing time spent turning to the reduction as well as faster mowing speed. No time wasted as the mower is cutting grass virtually all the time. As to long term quality, time will tell.
General advice
Grant in Iowa
Thomas,
Here's the general advice I usually give those seeking new yard equipment:
If you just want to mow, and your lawn is fairly level, then a Zero turn machine is just the ticket. The commercial grade machines are by far more reliable, and could easily last a homeowner a lifetime. To determine brand, pay attention to what the local lawn companies have on their trailers, and also consider which dealership is closest to your home. I really wouldn't recommend a lawn tractor unless the deal is too good to pass up.
If you want a single do-all machine for a modest sized lawn and driveway, I suggest a Garden Tractor. Garden tractors differ from lawn tractors in that they are designed to use ground engaging implements such as a tiller. This generally means they are built more robustly than a lawn tractor. John Deere, Simplicity, Toro, and Kubota all make good machines in this class. There are others which have regional success, but those are the big national players. Suggest you buy one from a dealership, as the support and training they offer is worth more than the discount you can get from the Big Box selling a lookalike. You suggested a snowblower, which differs from a snowthrower in that it incorporates a second stage blower to move the snow further. I suggest you make sure it is a true two stage unit. When looking at quality on these machines and their implements, look for a true frame separate from the bodywork, and the robustness of the rear transaxle. Before you buy, Google the "make, model and problem" to see what common issues there are with a given model. One of the drawbacks of this class of tractors is the lack of implement interchangability. This means you might pay as much for one of these machines with all the implements as you would for a larger more robust compact utility.
If you can justify the expense and versatility, consider a compact utility tractor. Kubota, John Deere, and Cub are the big players in this category, though there are others. These machines generally include a 3 point hitch on the rear of the tractor which will accept widely avialable implements. If you go this route, you won't be stuck buying a brand specific implement at the dealership.
FWIW,
Grant in Iowa
Thomas S Stockton
Thomas
Grant gave you good advice. The bx series of Kubota's are not much larger than a big lawn tractor but are built much heavier and are little work horses. all the major players make something of a similar size so you can shop around. I looked at them when I bought a tractor but they were to small for my needs.
I would go to www.tractorbynet.com and do some searching, they have a bunch of forums and are pretty friendly.
Tom
AZ in Colorado Springs
It's not a tractor, but it'll provide plenty of power with a big block Chevy motor!
