We value your privacy.
I think there is a general rule regarding "wood movement" when attaching solid wood boards as in the making of a cabinet. With the changing of the moisture content in the wood & room if the wood does not have room to expand it will split..not necessarily on the glue seam. Is this correct and where would one find the "basics" on wood movement and how to allow for movement?
You might see if your local library - or library system - has "Understanding Wood," by R. Bruce Hoadley. This is probably the best book on the subject for regular folks.
You might also read through the Forest Product Laboratory's "Wood Handbook."
At a more basic level, many comprehensive woodworking books have a chapter on this subject. Once you understand the basic concepts, there are other resources. For instance, right here on Wood Central: If you go to the "Articles" link at the left of your screen, and to the "Badger Pond" articles, and scroll most the way down to the FAQs section, you'll find an article on wood shrinkage with a chart that will help you decide how much space you need to allow for wood shrinkage.
One of the key concepts is never to attach wood cross-grain: don't nail or glue pieces with the grain running at 90 degrees. There are times when people violate this and get away with it, but it's always risky.
Woodbin.com has a 'shrinkulator" to calculate shrinkage. There are loads of variables such as what you are starting with and where the piece will live but this will give a rough idea of how much movement to expect in various woods.
Bill and Paul's recommendations are right on. I especially like Hoadly's book.
One little additional comment to your understanding:
It is shrinkage that causes a piece of wood to crack if both sides are attached to something immovable. Expansion can cause another piece to crack if it is incorrectly attached.
Wood expands with higher moisture content in the air - usually in summer without A/C. In winter, it is usually dry indoors, as the heating reduces the relative moisture coten of the room air and the wood dries and shrinks.
Depends on what your doing and how you go about it.
If your making a table for instance , attaching the top to the apron , one only need to use a system that lets the top expand and contract seasonally .
Buttons that hold the top down to the apron by a tongue that slides in a groove works well and is a traditional way to go about it.
A general rule is to avoid gluing parts at right angles to each other if the material is any width more then a narrow trim piece and both pieces are solid wood.
A exception to the rule and one that is used frequently in woodworking is a Mortise and Tenon joint .
If I make a piece of Furniture as opposed to Plywood cabinets , I use solid wood all around and this approach definitely needs to be preplanned, so the sides and top and bottom all move at the same rate.
As long as you use a system that predicts the movement and allows for it, then you should have no trouble in planning your project.
There are several , ranging from the buttons I mentioned to slots for screw heads to ride in, sliding dovetails for trim attachment and so on.
Read up on it, Hoadley is a recognized expert on Wood technology , as well as William T. Simpson , who authored many texts for the Forrest Service and Colleges and University Wood Technology courses.
Your assumption is correct regarding the need to consider wood movement when designing/constructing a cabinet. Hoadley's book is excellent. Here is a chapter from Bill Hylton's book on cabinet making that might be useful to you.
The situation I encountered was a solid wood white oak boards glued together (the split did not occur in the glue line) . They were attached to the side of the cabinet by dado at bottom, with screws, & rabbit with screws at top. Grain on both boards glued going in same direction. I did glue on a 3/4 inch face frame on the front of cabinet. Apparantly the screws and or face board did not allow for the winter time movement? Thanks for responses I will research further
Typically, cabinet sides of hardwood "float" in a dado/groove in all four sides of the frame. No need to glue or screw.
Another approach is to use "tongue and groove" boards, each board nailed or screwed, but with a small (say 1/32) gap between them. Each board moves a tiny bit, but the gaps allow plenty of room.
Or, if you need to screw a panel down, route out a slot in the panel and put the screws through the slot.
Lots and lots of ways to handle movement.
BTW, the glue is much stronger than wood, splits almost always occur in the wood.
Hope this helps. This forum is a great resource for dealing with issues like this.
Which season is drier/wetter depends on the climate. Here on the California North Coast, summer is pretty consistently dry, and winter, when it rains, the more humid season.
Whether houses heated better than ours are drier than ours in the winter, I don't know; but one of my chores today is finally taking down two interior doors that always swell and stick in the winter and cutting off enough to (I hope) cure the problem once and for all.
