REAL MILK PAINT
lathe review
lathe review
lathe review
Jerome Mills
I've been turning about 1 year on a jet mini lathe and am wanting to move up. I want to buy a really good lathe one that is very versatile with a min 16" swing. I see and read a lot about oneway and powermatic and jet. I have about 7000 to spend. any ideas or additional info I can read about to help me with this decision.
thanks.
Re: lathe review
Re: lathe review *LINK*
Phil Joines
There's also the Robust Lathes which are supposed to be very good but I haven't used one.
Try asking your question in the turning forum. Look under Message boards on the menu to the left.
Of course you will get as many answers as there turners. :D
http://www.turnrobust.com/
Re: lathe review
Re: lathe review
Post over on the Turning side. Be prepared for a lot of opinions.
It really depends on what you want to turn. if you want to turn big bowls - go for a Powermatic, Oneway or a Robust.
If you want to turn spindles and the occasional bowl, go for a Oneway, Jet or Nova.
With your budget - you can pretty much outfit your entire turning set-up, lathe, tools, chucks and all.
Re: lathe review
Re: lathe review
Joseph Mulherin, Sr
Consider on purchasing a new Shopsmith...five tools-in-one ...have had mine for 32yrs and it does everything I want to accomplish in my woodworking.
Re: lathe review
Jesper, Denmark
Re: lathe review
Jesper, Denmark
Don't ignore Canadian General.
Re: lathe review
Re: lathe review
Terry Quiram
Have a look at the Stubby 750.
Re: lathe review
Re: lathe review
I had one for 5 years. Compared to quality tools it's junk. Sure I did a lot of woodworking with it but even my bottom of the line Powermatic contractors saw will run circles around the shopsmith. A jet mini lathe with bed extension will turn like a dream compared to the shopsmith. I never could drill a truely accurate hole when using the shopsmith. My Delta drill press is far more accurate and powerful.
Re: lathe review
Re: lathe review
I have the Powermatic and have turned on most of the other lathes except Robust. It would be hard to justify spending the extra money. I'd spend it on accessories. My Powermatic will do all that I've asked of it. The other lathes might be a little nicer but it's really just in personal styles of turning. Of the ones I have turned on the Stubby impressed me most. Robust is getting an awful lot of great reviews and if I were to upgrade would have to consider it.
Re: lathe review
Re: lathe review
Joseph Mulherin, Sr
To each his own...and opinions too.
