Crowned tires on a bandsaw are awesome
wilbur
My 16" Walker-Turner bandsaw is set up as Michael Fortune describes in his Fine Woodworking article from 2004, which means that I have crowned tires, I don't have huge amounts of tension on the bandsaw blade, and that I have the blade centered on the crown, and have made sure that the table is aligned so that the miter slot and fence are parallel with the blade. I put on a new 1/2" 3 tpi blade on it at the beginning of October, and haven't touched the blade or detensioned the wheels since.
Earlier this week I was helping my older boy with his first Pinewood Derby car for Cub Scouts. He had traced an outline on the block of wood of the shape that he wanted the car to be. Of course, the 1/2" blade that I had wasn't suitable for cutting the contours of the Pinewood Derby car silhouette, so I put an 1/8" blade on. I loosened the 1/2" blade, took it off, put the 1/8" blade on, and tensioned the blade back up. I did not readjust the top wheel tilt at all. Then I went to cut out the contour of the car. I was able to get a perfectly square cut and testing with a scrap piece of wood afterwards, there were no drift issues with the fence.
After finishing up, I took the 1/8" blade off, and this is what I saw on the upper wheel.
This is the best photo proof I can think of that shows that crowning a tire works wonders for a bandsaw. The strip of sawdust is the sawdust that had collected under the 1/2" blade over the past few months. It sits evenly around the crown because the blade was centered on the crown. The groove in the middle is where the 1/8" blade settled -- right on top of the crown, exactly centered in the sawdust band, without adjusting the top wheel tilt or the fence for drift.
My cuts with the 1/2" blade before, the 1/8" blade for the Pinewood Derby car, and after I put the 1/2" blade back on my bandsaw afterwards were all square and drift free -- again, all without adjusting the top wheel tilt or adjusting the fence for drift.
