Old Watco - OK to use?
Mark_in_Michigan
I have a gallon of Watco Danish Oil that is at least 10 years old. I used some out of it when I bought it and it has been sealed since then. Stored in a heated garage the last 3 years, in an unheated crawlspace before that.
I am going to run a test by applying some and seeing what happens, but before that I thought I would see if anyone thinks it is still OK to use or not. I guess I am asking if there will be any drying issues since it is so old.
Thanks.
Re: Old Watco - OK to use?
After spending X hours on a project - do you feel.
lucky?
Heaven knows - I'm a pack rat. I keep things way beyond their expiration. I also use things that I really shouldn't.
The storage condition for your Watco were NOT optimal. You opened the can and removed some contents - thereby exposing it to air (oxygen). You left it with a "head space" (area above the liquid/solid). You stored it in an unheated space. Watco is mostly mineral spirits and solvents (75% or so) and the rest is oil and varnish - you probably didn't affect the mineral spirits - but you may have affected the oil and varnish.
If it has a skin or anything that doesn't dissolve with stirring - get rid of it. Don't even bother testing - use it as fire starter or something.
Before you test though - ask yourself a question - is a project that you spent X hours and Y dollars worth more than saving the $ on a can of new finish or less? I usually just use old finishes as fire starter for my burn piles.
For future reference - Bloxygen works well - it displaces the oxygen above your finish. I have a friend who has a CO2 tank - he uses it (much cheaper). I won't say what I use - because it is a safety thing.
Howard Acheson
I suspect that if you contacted Watco, they would say to replace it. There is an amount of resin (varnish) in Watco that dries and provides the only protective component of the finish. Resins stop curing properly after extended periods.
Test it on some scrap wood. Apply per the directions, let cure at room temperature for 4-5 days and see if the surface is truly dry. The major component in Watco is linseed oil so it may dry, and feel dry, but the resin could be remaining uncured.
Safest thing to do is to discard it and either buy new or make new. You can easily make your own by mixing equal amounts of varnish or poly varnish, boiled linseed oil and mineral spirits.
David Yoho
Mark, I think that time period and storage conditions say you should discard it and buy fresh. There's nothing like trying to save a few bucks on a project that you worked hard on, spent good money for the materials, and then find you have a mess because the finish is too old.
A good suggestion is to try only buying what you can use before the expiration date arrives. I used to buy Watco in gallons but found it's better to buy in quarts. I usually use them up before they are around too long but if not, I'm not discarding much. Working with fresh finish eliminates worries old finish will cause.
Michael Wangler
Mark,
I have a gallon of Watco I purchased from Woodworkers warehouse ~10 years ago. I continue to use it and I have not had any issues with it. My container does not seal that well and it does not appear to skin over or evaporate like other finishes Be safe and test it out first.
You mileage might vary...
Moses Yoder
Re: oops
Moses Yoder
I am not sure but I think your post provides prosecutable evidence of improper disposal of environmentally hazardous materials. Its basically a signed confession.
Re: oops
Around here you can start a fire with just about anything. You just have to make sure that you get a burn permit and don't use it to dispose of anything but "wood and yard waste". I'm not disposing of waste - I'm just using something to start a fire :b. I WON'T use gasoline. I will use mineral spirits, kerosene, charcoal lighter, paint thinner, etc.
Re: oops
R Payne
Local laws may allow you to start your fire with solvents but the EPA has regulations against burning some varnish resins and some oils. You could still be in some hot water depending on who has a problem with you.
ron
Mark_in_Michigan
No, it's not worth taking a chance after spending many hours and far more dollars on wood than the finish costs. That is why I was going to do a test first, but I was worried if it would truly dry as it should. The more I think about it I believe I will just dispose of it (legally) and start with fresh.
Thanks.
