More vanity help needed...
Gary Kittleson
Ellis may not quite remember this, but a LONG time ago he helped me with a design question on a bathroom vanity. This has been my first attempt with this type of a project, and while I have not really enjoyed much of the remodeling phase in the house (we gutted the old bathroom), I must say it has been quite educational! :\
I am finally preparing to bring the vanity into the new bathroom, and could use a bit of assistance from you who know these things... I built the vanity with a base for it to sit on, creating the toe kick. I'm not sure if that was the best way to go, or not, but there it is. My error was in not truly appreciating just how out of square my floor is.
I have shimmed the base level, but end up with almost a 1/2" gap under the low side of the floor, which happens to be the end which shows.
My question is: What in the world can I do with this gap? The end of the vanity looks like:
Do I leave the gap? Try to fill it with something unobtrusive? I'd rather not put a piece of quarter-round there, but can't think of anything else...
Any suggestions would be appreciated. I'll post more completed photos and information after I can think straight again! (No laughing, now Bryan...)
Re: More vanity help needed...
Dave Bair, Eaton Rapids, MI
There appears to be no facing on the front of the toe-kick. Add one that's tapered to match the gap. It can be quite thin, maybe a quarter inch.
Gary Kittleson
Yes, I should have addressed that.
I have a piece made up for the toe-kick...well, make that HAD. I'll make another to fit the angle, so the front of the vanity will not be a problem.
Really, I'm wondering what to do on the end of unit. The end of the vanity is a panel, with a bottom rail, and two vertical stiles...now it will be 1/2" off the floor.
AZ in Colorado Springs
It seems to me your dilemma is that the vanity includes a side piece that was intended to extend to the floor. Perhaps you can disassemble the base, plane all the pieces down by about 9/16" and reassemble it. Then you can scribe the side piece to the match the floor contour. Whatever you put on the front of the base will, of course, have to be shorter by the corresponding amount. And your toe kick will be a bit shorter than intended.
May also affect the plumbing connections inside the vanity.
Gary Kittleson
I like this idea....thank you. The base will be easily disassembled...
I can't think of any real downsides.
:D
FredD
Since you have gone this far, AZ gave you easy way out .
If you do any more base cabinets I advise incorporating the base into the box thereby making the cabinet a complete unit.
This is far easier to do , then trying to extend a side down the base after the fact.
FredD
shoe molding
Bill Tindall
Except in this case you will need to make it taller than normal.
Is there a reason the cabinet has to be level with the earth and instead of level with the floor? I had this issue with a kitchen peninsula and just let it conform to the floor.
Re: shoe molding
Alan in Little Washington (NC)
Shoe molding.
Also in the future make the wall end stile extend past the cabinet so you can scribe it to the wall- both wall and floor can be out of plumb!
Re: shoe molding
Gary Kittleson
I took AZ's idea....worked excellently!
- I wanted the vanity top level with the Earth, so that any water escaping from the sink (read....children) will not run the length of the vanity, ending on the floor. I have this problem in the downstairs bathroom, and don't want it upstairs also!
- Yep...I did run the face stile a bit long, but ended up pretty good there!
- Thanks everybody.... ;)
Shorten the panel so the top and bottom stiles match, then wrap your toekick around the corner. The panel shown looks a bit strange with that huge bottom stile. Shortening the end panel to match the bottom edge of your face frame will likely improve your design as it will continue ("return") the shadow line established on the front of the cabinet back to the wall. Your cabinet will have a greater unity as a "supported box."
JMO- YMMV ;)
