Damaged My Freud Ultimate Cutoff Blade
Steven Bellner
As always happens when one trys to do things too fast, I had a minor "accident" that thankfully only caused some damage to my crosscut blade. It appears I had placed a drill bit I had just finished using for predrilling some small holes (5/32") on my miter saw table. I was outside working on my deck, and the miter saw table apparently presented itself as a convenient place to lay things down (note to self - always put it up when you're through with it). I went to cut off a scrap piece to use as a spacer, and I didn't see the drill bit and apparently pushed the bit against the fence in front of the wood. Here comes my nice Freud 12" blade comfortably slicing through a small cutoff when it encounters the drill bit, and sends it flying. Fortunately all safety guards were in place, and the shattered bit shot out the back of the saw along with part of the blade.
Now my blade has one missing tooth and two chipped ones. It's not bent, but has the three consecutive damaged teeth. Is this saw scrap metal, or can it still be used reliably? I've made some test cuts, and they seem to be of high quality, but I worry about the blade now being out of balance, or possibly throwing more teeth.
It's amazing how much damage a 2-dollar drill bit can do to a $100 saw blade. And here's the irony. I was using recycled wood, and went over it and over it with my metal detector so as to avoid this very scenario. Got a couple of office staples out using the metal detector, but they probably would have not even made a scratch on the blade. But hardened tool steel - that's a different story.
