New Use for Wixey Angle Gauge
Alan in Little Washington
Since Wixey is not planning to make a digital tilt unit for the tablesaw, I decided to take matters into my own hands.
I made a simple bracket for the Wixey and attached it to my saw- now I have a bit more precision, more convenience with a continuous readout, and it is easier on my eyes.
First I removed the blade elevation lock, the handwheel setscrew, the handwheel, and the tilt angle pointer.
I made a wooden bracket (too lazy to make it from steel) that slips over the tilt shaft and attaches to the tilt pointer bracket by the pointer screw. I attached the pointer to the top and mounted a small piece of steel angle at the end:
Then I reinstalled the elevation crank and lock knob:
How it works:
I set the blade to 0 deg. tilt using the Wixey in the normal manner - set the Wixey on the top of the saw, zeroize it, attach it to the blade disc, and turn the tilt crank to adjust the blade to 0.0 deg. using the readout.
But then, however, instead of putting it aside, I place the Wixey on the little steel shelf at the end of the wooden bracket. The shelf is tilted slightly but that doesn't matter since I zeroize the Wixey again. Now both the blade and Wixey are calibrated and at 0 deg. (once adjusted, the pointer also indicates 0 deg.)
Then, using the Wixey readout, I tested it by tilting the blade to various angles, first to 22.5 deg.
the pointer also reads 22.5 deg.
Then, using the Wixey readout again, I attempted to tilt the blade to 45 deg. but hit the stop which was either improperly adjusted or caked with dust, so I could only get 44.7 deg.
That is what the pointer reads too, at least that is what it looked like it was reading, since it is not that precise! (there is a little parallax due to the camera angle).
This worked very well, was easy to do, and required no permanent mods to the machine!!! Maybe I'll send it to the magazines as a tip.
Re: New Use for Wixey Angle Gauge
Now that is cool!
Neal in San Jose
The best part is that the Wixey is not permanently tied down. This just got put on the top of my "round tuit" list.
Re: Now that is cool!
FredD
Alan, you lost me somewhere, how is that clever little installation any better or faster then using the Wixey on the blade as usual?
FredD
Not Alan and I don't own the digital device but I can see advantages. 1, it's "stored" there and there is no need to get it out and put it up. 2 You don't have to raise and lower blade to set it. there are probably others but my 4 mo. old granddaughter lust joined me and is helping me type.
ebd
ebd
I use mine on the blade and check the angle from both sides of the blade. You only have to make sure that you are on the flat of the blade. I also use it to set the jointer angle and the table on the band saw and drill press. Very handy gadget.
Another...
John in NM
You can set the angle while the blade is running. Doesn't sound like you can do that normally - but I've never used one of these dealies. :D
FredD
That is the way I do , I only was wondering how the setup was better or faster then using it the normal way, on the blade or whatever else you use it for.
People who change blade angles while the saw is running might want to rethink that practice. It would make reading the Wixey a lot easier., don't you think?
FredD
Why?
John in NM
"People who change blade angles while the saw is running might want to rethink that practice."
Granted I don't do it now, since I invariably use a square to check the setting (:D), but I see no real safety concern with changing the blade angle or height (that I do all the time) while the saw is running. Saw's not going to jump up and bite, I just don't see the need for such a caution.
About the only case I could see would be if one were using a ZCI, and in that case, having the saw running would tell you in short order to shut it down and change the insert, probably before the blade were seriously damaged. Making the same mistake with the machine off one would likely not realize the error as quickly and tweak the blade beyond further use.
So I'm just wondering what your reasoning is here Fred. I may have missed something obvious - like that's never happened before! :D
It's interesting but I'm not sure I see the need either. I put it on the blade. I also use it to set my miter gauge. I put the miter gauge down on the saw table so the guide bar hangs down. I put the Wixey on the guide bar and make the adjustment. It gives me a perfect angle.
It's very handy to set the Bandsaw table angle, setting the Disc sander table back to zero or any other angle. Same is true for the Scroll saw table. It makes repeating angles really easy on these tools.
I use it on my metal lathe and mill to angle pieces before clamping them in the vice.
Just for fun I used in on my Brace and Bit to set the leg angles for the last stool I made. I've always done this buy eye but though, why not, maybe the shakers would have used one if they had it.
Alan in Little Washington (NC)
I use mine for everything like John Lucas. Barry and John in NM pretty much nailed the advantages of my tablesaw mount except how much easier it is to see with my weary, old eyes. It is just convenient as heck to set it once and forget it (I haven't touched the TS in the two days since I took the photos. I turned on the Wixey and it still read 44.7 deg.!!)
Frankly my saw's sharpened angle pointer does a pretty decent job, but parallax is an issue. I'm not dyslexic, but have you ever thought your were setting the tilt to something like 10.5 degr. when in reality it was 9.5 degr?
One of the real beauties of this, since the Wixey is not permanently mounted I can just pick it up and take it over to my jointer, bandsaw, etc. Granted, I will need to recalibrate once I get it back on the TS, but as long as I would be doing that anyway, what better place to store the Wixey than in a place that also serves a useful purpose!
Now, a few cautions about these sensitive angle gauges- First your floor or machine does not need to be level, but if you have a really sloped floor . . . you should orient the saw so any tilt is in the direction of the saw's arbor. If it isn't, the digital gauge will be trying to reading a compound angle and not be as accurate as it is capable.
Second, a flexible floor or even the extension wings can affect the reading. The floor of my second story shop flexes enough to make my angle readings change by +/- .1 degree depending on which side of the blade I am standing or if I lean on the left or right extension wings.
These really aren't problems as long as you know about them.
Idea to improve the zeroing step...
Grant in Iowa
Perhaps you could make your wixey mount tab adjustable such that it can be adjusted to the same angle as your saw top when the blade is at 90. This would mean that when returning the wixey to its "home" on your mount, you'd only have to set it on the top of your saw table, press zero and then place it on its bracket. Any deviation from zero at that point would mean you aren't already at 90....which is of course very possible.
Doing it that way would ensure each time that the saw blade is at 90 degrees when you start. By zeroing it on your bracket, you introduce the possibility of error if the saw blade isn't already at a dead on 90.
thoughts?
Regards,
Grant in Iowa<---eyeing his Wixey in a new way.
Related question
Nice trick, Alan. And thanks for the great pictures.
One question raised here was about the advantage of measuring the arbor itself (as your trick does) vs gauging the angle of the blade plate. I don't own a Wixey, so I can't personally investigate this, but I'd like to know if the angle changes when measured at different locations on the blade. Technically, blade plates are not flat until they reach running RPM, because of the way they are tensioned at the factory. This "potato chip" effect is tiny in most cases, but may be detectable with a device like the Wixey that can read to fractions of a degree.
I suspect it's not a big deal, but I don't know.
My compliments to all
ron
Great idea Alan.
Great questions and suggestions everyone.
You guys are smart and ingenious. Thanks for sharing.
I've got one of those do-hickies and love seeing what they can help with. And I'm not fond of sticking it to the blade, so I plan to give this idea a whirl once you folks get the polishing done on Alan's spark.
Re: Idea to improve the zeroing step...
Grant, that is an excellent idea!!!
There is one consideration however, the 0 deg. stop must be set perfectly and stay that way. Any dust build up on it will affect the Wixey. Running the blade to 0 against the stop must be reliable and repeatable.
But, if you carefully adjust the stop, keep the machine clean, and check it regularly, after using the Wixey on another machine, you can, as you suggest, just crank the blade to the vertical stop, put the Wixey on its shelf and hit CAL! Just that simple.
Thanks for the great suggestion! Too bad I already submitted my tip to the mags.
Re: Related question
Ellis, that is certainly a consideration. Some blade disks are not ground flat, but I suspect this affects any angle measuring device, not just the digital ones. (I wonder how many folks set the protractor against blade disk near the table but against the sides of the blade teeth at the top when they measure blade tilt . . . oops!?!?!) :O
I don't know how much affect a non-planar blade disk will have on the measured angle vs actual cut angle. Each blade is different. It may or may not be insignificant from a woodworking standpoint. It might be worth studying. You certainly don't want that kind of error in a metal milling process. An error of .1 or .05 deg. would likely make no difference except in the most demanding woodworking operation. This amount of error is certainly much less than you can expect just using the scale on the saw.
Frankly, the only way to precisely calibrate blade tilt is not using the blade, but by measuring the angle of the cut it makes, which takes into consideration all machine and blade factors. But now we are really getting "a" retentive about precision. :D :D :D
Re: Why?
FredD
John ,
I think that common sense dictates that introducing a potentially dangerous step into a innocuous routine , like raising a blade to a specific height, while the saw is running can ruin your whole day.
But that is just what I think , some people can read and drive at the same time .
FredD
FredD
Are you going to adjust the 45 stop on your saw to agree with the Wixey or any gauge like a combination square or Draftsman plastic triangle?
FredD
FredD
"Frankly, the only way to precisely calibrate blade tilt is not using the blade, but by measuring the angle of the cut it makes, which takes into consideration all machine and blade factors. But now we are really getting "a" retentive about precision. :D :D :D"
There is one other way I can think of Alan and I do it for blade angle checks and lining the fence and the mitre slot to the blade with a 10" steel test blank ground to a guaranteed degree of flat.
This one I have is made by Nordic Saw and Tool in Turlock . CA.
It makes the afore mentioned tasks much easier and more accurate.
FredD
Well, to each their own...
John in NM
I still do not see the potential danger, but of course no one should engage in techniques with which they are not comfortable.
Just to be clear, no one is advocating getting anywhere near the blade here - both hand wheels are well under the table.
I might, but from experience I don't trust the stops, even properly adjusted ones.
When adjusting either stop, I would certainly use a multiple tool approach- engineer's square, Wixey, and a test cut or two. The 45 stop is not as critical.
Besides protecting the worm or trunion gears from over-travel or damage, I suspect the main reason manufacturers added a 45 stop is allow the user to be able to quickly tilt the blade to the second most used angle. But if it is not set properly or is caked with dust which is common, it is nearly useless and this goes for the 0 stop as well.
In fact, with the Wixey setup I don't need to worry if the 45 stop (or the 0 stop) is correct or clogged with dust if I intentionally set it to greater than 45 (46-47 deg.) (and less than 0 deg.) if I don't use them! :D
Compacted dust on the stops, if they are used, can result in a 1 deg. or more error.
FredD
I am not trying to upset you Alan, but your 45 and 90 saw stops when properly adjusted ensure that the angles between , like 22 1/2 and 30 are dead on.
If you saw has a typically primitive pointer in a hard to read place , that's not the fault of the saw stop, which makes the Wixey a handy little devil , but all of that aside , I would still want the stops to be accurately set, it's not that hard assuming your saw was out of whack. Then I would want the pointer to echo those settings.
The stops are time saving devices and in a shop time is money.
FredD
No problem, it is a good exchange that others may learn from.
Not to make any particular point but just because the 0 and 45 stops are correct means nothing with respect to the marks on the typical applied angle scale. Case in point, I can't tell you how many (primarily low end, "primitive") saws I've seen where after setting the 0 and 45 stops and setting the pointer at zero, as you tilt the blade the pointer does not track properly at mid-scale and is off by more than a degree at the 45 stop!!
I sharpened the pointer tip on my Unisaw. But just look at the width of some of the angle marks- where on that wide mark is the correct position. The width of the 22.5 and 45 degree marks are almost .3 degrees wide!!!
I don't disagree that accurate stops are nice and important in a production environment, but again, if they become impacted with dust, which you necessarily won't detect, your 0/45 stops may be off.
Right, Fred
When I toured Delta assembly plants in Memphis and Taiwan, as well as the Robland plant in Belgium, they were all using steel test plates for calibrating the saws. I even managed to snag one of the plates, although it must have been lost in my shop fire in '99.
I'm mostly into empirical methods anyhow. I just brought up the blade tensioning observation because I know it exists. I doubt that it could possibly be significant, even to the degree of accuracy that the Wixey or other fractional-degree measurement devices might be capable.
Cheers,
FredD
Well your right about the wide indicator marks on the tilt scale Alan, some look like the width of a paint brush and are only good for a rough estimate.
This is precisely why I used Drafting plastic angles to set any common angle between 90 and 45, then along came Wixey at the nearly the end of my useful working life , sigh.
About dust collection getting into the stops on the saw, I can tell by the feel and sound of the trunnion bumping into the stop whether the stop is clean or not, but I suspect that comes from endless hours using the same saw every day, when I actually worked for a living. ;-))
FredD
Re: Well, to each their own...
FredD
