Design problem
Design problem
Design problem
james runchey
I decided to cut 4" off an end table and realizing the lamp would be too low on the cutdown table, I decided to make a box, 4" high with a drawer to keep remotes in, to elevate the lamp. I made a box 12" square 4" high with a drawer out of some nice walnut I had on hand. The base is 3/4 thick and the top is 1/2" I used 1/2' for the three sides set into shallow grooves top and bottom set in from the sides leaving about a quarter inch reveal all the way around. The grooves run around three sides. With this glued up tight, I think the top and bottom are liable to split when wet weather comes. Anyhow I'm thinking of cutting the sides out and redoing the box and am wondering what the right way would be.
Re: Design problem
It can work
Jim, if the three sides are mitered together and the top and bottom have grain running left to right as you view it from the open side, you can safely glue in the back side piece and a few inches of the left and right sides. Somewhere near the front you'll need to make the equivalent of slot screws from the top and bottom into the sides. This way, the back stays put and the top and bottom can shrink and expand forward. The slot screws will keep the box together and allow for the wood movement. The drawer front will come to rest against the sides or inside them as may be.
Re: Design problem
Re: Design problem
John Veerkamp
I don't think you'll have a splitting problem with a 12" box. In my experience it is usually the dry weather that causes splitting not wet. My 2 cents.
