Best primer for painting wood & hardboard
Tim Greif - West of Chicago
I'm making a baby book and coat rack for my new grandson. My son and DIL want to paint it white. It's constructed of clear pine with a tempered hardboard back panel grooved on the tablesaw to look like wainscot. I'm not sure what to use as a primer. I was thinking BIN or 123, or maybe a simple coat or two of Shellac or Seal Coat. Years ago I remember using a couple coats of shellac before painting with a gloss enamel to achieve a nice painted finish. It'll probably be painted white with a rattle can.
Any advice will be appreciated.
Tim
Re: Best primer for painting wood & hardboard
Clint Searl
Flat white interior latex
Clint Searl
Couple coats; can be sanded smooth; will accept any topcoat.
Clint
Jesper, Denmark
Jesper, Denmark
Shellac is a good idea. It does not buid-up any appreciable surface thickness, and does an excelent job of sealing any knots, so the resin does not show through the final finish.
FredD
Use B-I-N Shellac based white primer and reduce your work , don't forget to sand it with 220 Garnet before the paint is applied .
FredD
