200+ woodworking book reviews
Epoxy
Epoxy
Epoxy
Woodie49
Will Epoxy still harden after the expiration date, adouth one year?
Thanks
Re: Epoxy
Rick L
Re: Epoxy
Rick L
I would say yes but exactly what brand and type are you referring too?
As usual most folks fail to give enough info in their question!!!!
Some brands of Epoxy go well beyond the one year period. System 3 doesn't really have a time frame. The other nice thing about S3 is their regular and fast can be used down to 35 degrees and if it goes below freezing before the set time it will continue curing when the temp rises past 35 degrees.
Re: Epoxy
probably....
John in NM
It's likely to be ok, depending on storage conditions. Why not try a bit and find out? :D
Re: Epoxy
Test it-
Mix up a small batch on some wax paper. After it cures (if it does) try and break it. That will tell you if it hardens properly. I often do this test when trying out new materials that I add to the epoxy to color it. Some materials change it's characteristics quite a bit.
Re: Epoxy
Most Epoxy needs heat to cure.
Keith Newton----Little Rock, Arkansas
A lot of shops are probably pretty cool this time of year. I like to do my mixing while holding my mixing cup under the hot tap while it runs down and around the tilted sides.
As others have stated. While most will give one year expiration, there aren't any VOC's to escape, so they are usually better than let on. Sometime the activator darkens when stored in a steel can, and a big lump can form in the resin. The lump will re-liquify when warmed.
But your best answer is to mix a test batch and see for yourself.
