Filling Pores on Oak w/WB Poly
Bob S
Will this topcoat eventually fill the pores of my White Oak table? 3 coats into it, and i'm having second thoughts.
Bob S
Re: Filling Pores on Oak w/WB Poly
Jesse Cloud
It will take a very long time to level it out that way and you will have so many coats the piece will look like plastic.
Overall, it would be faster to sand it down, put in some paste filler and then topcoat.
Or just live with the pores...
Sorry I don't have a silver bullet.
Howard Acheson
What are doing between coats? That's the important question if you are aiming for a perfectly flat surface. You should be flat sanding with 220 paper backed with a soft faced felt or cork. Optionally, use a cabinet scraper to remove all the surface finish. Sand or scrape until you just see unsanded spots where the finish is still in the pores. Apply another coat and when dry again flatten the surface. With deep pored wood, this could take quite a few coats with between coat leveling.
For the future, using a special purpose grain filler will be much faster and may give you better results.
Bob S
It is not that bad.... I am not even sure that I need to fill all the pores, I am new to this. First time making a piece out of oak. (well, i made cabinets for bathroom, and finished with a heavier varnish, they filled up pretty much fine (yellow oak, easier?). I am not looking for a plastic look!! yikes.
I thought in all honesty that at least 3-5 coats of water poly, were in order as the coats are so thin.
Jesse - How many coats are typical?
In between coats I am knocking down the 'bubbles' and dust 'nibs' using a clogged maroon 3M pad. Using hands, no backer.
I may not need the total smoothness, but again, just expected it.
The total finish is comprised of:
1. Sanded to 150 grit. Raised grain. Re sanded to 150.
2. Aniline Dye (Gray), water based for attempt at 'grayed/beach look finish).
3. 2 coats of 1# cut , blonde dewaxed shellac.
4. Water Based Polyurethane.
I brushed the first coat on but had many issues with foaming. 2nd coat I tried foam pad with more success but it seems this imparts a much thinner coat, and had now realized I thould be trying to fill the grain. 3rd and 4th coats with brush, and pores are almost sealed.
I am looking for a satin/semigloss finish for my end result. Please advise!!! A little bumpy grain won't kill me, but the look is key.
Only three ? . . .
steve mackay
My "production" bases for my models are oak, stained then poly. I don't even take a look at them 'till there are five coats on. Then sand and five more (or untill it looks like glass). I ALWAYS budget a week for the process.
