Finishing Very Curly Soft Maple
Roger T
Morning all,
My current project is a pair of Sheraton end tables with very curly soft maple. All the fitting work is done and I am now in the process of surface prep. I am doing as much prep now, before glue up as I can.
Because of the amount of tearout involved with the machining of these parts, A lot of scraping and sanding is involved. I am using the Norton 3x paper, at 180 grit to get the job done.
My finish schedule will probably be something like this.
Prewet the wood to raise the grain and sand back.
Lightly wet the wood to even absorbtion of the Transtint Dye with sanding back to just leave the color in the curl.
One or 2 coats of Shellac to seal in the color. Level with a grey scotch brite pad.
Final coats will be one of the many Water based Lacquers that are now available. All the finish coats will be sprayed with a STM HVLP sprayer in my basement.
Am I already going to far with the 180 grit, or do I need to continue on to 220 grit to have a flawless finish. I have never worked with wood that has this much figure in it, and dont want to make a mess of this either.
I am open for any and all suggestions at this point.
Thanks much for your insight.
Roger
