Delta saw pulley alignment
Donn
Donn
I was given an old Delta cabinet saw. For the price ($0) I figured it was worth the effort to fix it up to replace my Craftsman contractor saw. Everything was going fine until I started to install a splitter/guard and realized the jackshaft is not aligned with the guard mount or motor pulley. Does anyone have information on how to move the shaft axially in the trunnion?
Re: Delta saw pulley alignment
I'll punt to the real mechanics in the crowd on this, but whenever I changed bearings on old Unisaws, I just pressed the arbor in until it stopped, then secured it with the washer and nut. I guess I'm not visualizing what isn't in alignment and how far off it is -- nor which flavor of Delta saw we're talking about here.
del schisler
can't you just move the pulley's. Instead of moving the shaft ? I would thank the shaft and beiring's are fixed? or in with clip's. Maybe a model number and look up the manual ?
Donn
Donn
I have a photo with notes showing my problem but I don't see the "upload imbedded file" button any where on the reply page.
Donn
Donn
Got everything taken apart and found that one of the arbor shaft bearings were not fully seated and was holding the shaft too far out. Now I just need to get new bearings because if I'm in that far I'm not putting it back together with old bearings.
