200+ woodworking book reviews
Need some aluminum bushings made
Joe Pack
I barely consider myself a woodworker/turner. I certainly do not consider myself a metalworker, so I am looking for someone who is a metalworker and would be interested in hiring out for a small job. Essentially, I am looking for some greatly oversized pen bushings. I made my own from wood, but they tend to wear out fairly quickly.
I need a set (possibly 2 sets) of aluminum bushings to help in a production type woodturning job. I can't draw on the computer, but I do relate to food well, so my best description is this...
Imagine a donut measuring 2.5" diameter x3/4" thick with a 1/4" center hole. Now imagine a smaller donut measuring 1" diameter x 1" thick with the same 1/4" center hole. Now stick them together into one solid piece so the smaller donut is sitting on top of the larger donut with the 1/4" holes lined up.
The completed "stack" will slide onto a 1/4" shaft. The 1" diameter will fit inside my stock, serving as a jamb chuck of sorts. The largest diameter will serve as an O.D. sizing bushing.
The second part of the set will be the same design, but the largest diameter will be 3" instead of 2.5.
These measurements are pretty close, within 1/4" or so in diameter.
Anybody interested in a small metal lathe job? If so, send me an e-mail with a phone number, or reply here and I will e-mail you my own phone number.
Re: Need some aluminum bushings made
Nick Tuzzolino
Some turners make durable pen bushings like you are talking about out of corian. I intend to try this myself in the near future.
Galen Vetterick
Joe
Big pens! :>)
Have you looked at material cost for aluminum? IF you can get a metals supply house to saw short pieces of round bar you will at least have to buy a foot.
2 1/2" round bar would be a minumum of $40 and 3" at $50. Not sure what shipping cost would be depending on your location.
Then you need to be able to resaw off 1 3/4" lengths to turn what you ask for.
Turning 3/4" off the 2 1/2 and 1" off the 3" will take a while on a smaller metal lathe.
You can make a lot of wood bushings for what the aluminum will cost.
The Corian idea mentioned, you could glue up 3/4" thick if you really did not need the full 1" inset in your wood piece. Might last longer than wood depending on how often you cut into the bushing anyway.
You did not say how many pieces are needed in your production run.
You might find a shop that has aluminum plate flange drops as many do not use the last smaller centers. That is just more weld up and turning though.
You did not say if you would provide materials and maybe a rough idea of what you expected to pay. I assume alloy is not critical.
Sold my metal lathe but I wonder what you expected them to cost. Setup and labor may give you sticker shock.
Try Home Machinist or Practical Machinist sites
Google those two, and you should be able to find the sites. Last I looked (a couple of years ago now), you had to register to post on the sites, but registration was free.
Thanks for all the tips.
Joe Pack
Thanks for all the tips. I appreciate the ideas.
