Yellow glue creep data
Bill Tindall
Creep explained and defined: Creep is an inherent property of any polymer. All adhesives are polymers so all adhesives can/will creep more or less. The more or less can be sensitive to ambient conditions of temperature and humidity, stress and time under stress.
While a piece of dried glue (or any polymer) may appear to be a rigid solid, down at the molecule level the extremely long and tangled together polymer molecules are wiggling, more or less. A good analogy is at the molecule level the dried blob of glue looks like a blob of worms. If the worms are cold they aren't wiggling much. If they are frozen they aren't wiggling at all. If they are warm and wet they are wiggling enough that the mass of worms will conform to the shape of the container, they can be stretched, or even pulled apart without breaking any of the worms. Ditto for the glue blob molecules. If we grab each end of the worm blob and pull the worm blob will extend. This extension of the wiggly worm blob in response to the stretching force is creep. For the more technically inclined, creep is the slow deformation of a polymer(material) in response to stress.
Creep is measured for a polymer by molding a strip of the polymer, clamping one end rigid and hanging a weight off the other end. The lengthening of the strip is measured over time. Creep is this lengthening. No molecules are broken, in fact the material is not broken, in a creep test. Adhesive creep is measured by gluing two pieces of non-creepy material together, clamping one end and hanging a weight off the other. The lengthening (elongation) of the assembly over time is creep.
Yellow glue creep: There is reason to fret over yellow glue creep because the people that make the stuff say you should. They have lawyers and worry about law suits if you glue your house together with yellow glue. But do people gluing furniture need to worry about yellow glue creep? Well, here is some data and some caveats to go with it.
The experiment and result: Two maple sticks were glued together. Total glue surface is 1.5 sq. in. A scribe mark was made through the joint to enable movement of one strip relative to the other to be detected in the creep test. The joint was cured for one week. Then one end of the assembly was clamped to the rafters and a twenty pound weight was hung from the other end (see picture). The assembly was hung for 60 days. During this time the temperature was between 65 and 70 degrees and the humidity was between 45 and 55%. The scribe line was examined after 60 days. I could detect no movement of one strip relative to the other and I think I could easily see 0.002" of movement if it occurred.
Conclusion: A well cured joint made with Titebond Regular glue does not significantly creep under quite a large load in 1. 60 days, 2. at 65 to 70 degrees F, and 3. at 45 to 55% relative humidity.
Caveats: I might have been able to detect creep if the joint had not cured well before the test, or the temperature or humidity was greater or the stress was applied for a longer time.
Yellow (or white) glue is formulated so that the polymer molecules (worms) are essentially "frozen" by "hydrogen bonding" (chemistry term) at typical ambient conditions so it was no surprise that I saw no creep under the conditions tested. At 150 degrees or thereabouts I would have seen significant creep and at wet 200 degrees total failure of the bond.
Stressed applied perpendicular to the long grain of wood will cause the wood molecules to creep. This creep will lessen the stress on a bent lamination over time.
