Jet Bandsaw Mods
Steven Bellner
I have a Jet JWBS-18, purchased in 2004. This has been an excellent saw in all regards except one. The lower Carter-like saw bearings are a tremendous PITA to adjust. The bearings are mounted on a bracket, and that bracket is secured to the saw by two allen bolts. The front one is relatively easy to get to, but the back one almost requires the removal of the table to get the bracket properly adjusted. I believe Jet recognized this problem, and re-engineered this part, but the modifications are not backward-compatible.
I was looking at the general layout of the bracket, and thought if I drilled a hole through the table directly above the bolt, I could get a long allen wrench down into the bolt a lot easier than trying to use the stubby wrench that came with the saw. Firstly, has anyone else with this saw had problems adjusting the lower guides? And secondly, does the proposed modification sound feasible? I don't want to simply go start drilling holes in the table top if I am missing something obvious.
FWIW, when I take the time to properly set up the saw, it can resaw a piece so thin it looks like a handplane shaving. I use a Timberwolf 1" 3-TPI PC blade for resawing, and use their "flutter test" for tensioning. They tension out at a much lower setting than the machine indicates. I don't seem to have the flex in the frame I have read others have had. That may be more related to their 16" saw.
