Sharpening Bench
Sharpening Bench
Sharpening Bench
Doug Reynolds in Seattle
I am planning a sharpening bench for plane blades and other hand tools. It will be a butcher block top and trestle leg design with cabinet storage below. My question is, how tall should it be as I would think it should be shorter then the usual woodworking bench.
TIA and Happy New Year!
Re: Sharpening Bench
John Veerkamp
A dough kneading top in a bakery is 30-34 inches high.. I'd plan in that range adjusted for your leg length. It should be comfortable to keep downward pressure on the iron but high enough that you don't have to bend over.
Jesse Cloud
I prefer to sit while sharpening. If not, the old knees complain and cause me to hurry, which is never a good idea when sharpening.
Gary Smyth
Here is mine before I had to use the space for other more/less important stuff. Mine is 37� long (40" with the top) x 28� (31" with the top) deep x 38� high (40� with castered base). I�m 6� 1�. It�s comfortable for me -- I tend to hold things high and look closely at what I'm doing. It holds two grinders and two buffers easily. I can do most any sharpening I need � wet or dry. I fitted the top with Formica because I wanted to use the table for other stuff, and I wanted a "clean" undrilled assembly top if I removed the grinders. Formica also because of oil and water and because the fine grit gets everywhere and it permanently sticks in the wood. If used, there is no pretty sharpening station. For that reason I'd rethink the butcher block top. The Formica didn�t hold the grinders and buffers well at speed so I added a �� neoprene mat. The mat burns a little, but it cleans up grit, splatter, water, with a hose and holds the stuff on the top better. If I did it again I�d make sure it had a sheet metal top fitted � and a pretty heavy gauge too. I tend to use that top to pound on more than was originally intended. My top is wood baltic birch core 1 3/4" thick. Even with the weight of grinders it is flat (so water doesn't pool or flow toward power tools) and the overhang edge can hold clamps if something needs held. I'd make my top have more overhang than 1/1/2" and build custom "frames" for the bases of the grinders to fit into if I ever make another. One good thing about not bolting the grinders is that it forces me to use a soft touch. It makes things a little more safe.
You�ll be surprised how much you accumulate for sharpening � safety shield/glasses, grinding wheels, buffing felt, hard and soft, cotton/muslin, wire wheels, cup brushes, rouges, plate glass, and wet and dry grits for chisels, oil and containers for various stones, etc. I store it all underneath. The wheels are mounted on plywood slides and hang. That way the wire, felt and cotton wheels don�t get flat spots. Perhaps mine will give you some ideas.
shouldn't top be water and oil resistant
Bill Tindall
.....and readily cleaned. I would think Formica would be a better top choice. Black griding grunge isn't going to look good on maple.
Most everyone sharpens on the bench so bench height certainly works.
Some thoughts.
I made a sharpening "cabinet". I have drawers on one side and a door on the other.
The drawers hold jigs and sharpening supplies. The door side holds a water tub with stones and my tile saw.
My top is "shower board" that is coated. It is in an oak frame with a 3/4" plywood bottom. The oak frame fits over the cabinet base (which also has a 3/4" plywood top).
I used shower board because I can easily clean it. I can also replace it if necessary.
Moses Yoder
Re: Marble
Moses Yoder
My sharpening bench has a wood top where the grinder is attached and then marble tiles where the honing stones are used. The wood gets dirty but it is a work bench; the marble is easy to keep clean.
Joe Mohnike
I have a grinder, a dual shaft buffer and a wet grinder set on a lazy susan, at eye level.
I do this so that I can stand to the side and see how the bevel while grinding lathe tools.
I keep my stones in a lidded box each fitted and at the same level, so that I do not have to keep adjusting my "General" honeing guide. All the water/oil etc. is trapped by the box and no bench clean up. The box is large enough so that I can take my honeing guide apart and store it in the box.
Just a different approach.
Joe M.
FredD
As long as your still in the panning stage Doug, I suggest you get a copy of Larry Williams CD on grinding and sharpening edge tools.
You will find his bench is simple, well thought out and his equipment traditional , not expensive.
FredD
