Jet DC1100/1200 Owners
Rick Haverstock
Just scored a primo Jet DC 1200 off Craigslist and am adding a Wynn filter and replacing the cloth chip collector bag with a plastic one. Do any of you Jet owners of the 1100/1200 have this or a similar setup? Jet makes a snap ring for the plastic bags (part # 331038) that looks like a good solution compared to using the band clamp from the cloth bag. Anyone have any thoughts on or experience with this?? Thanks !
Rick Haverstock
Re: Jet DC1100/1200 Owners
Jerry Gibbs
My 1200 has the snap ring and plastic bag. The ring works well, but fits on the inside of the filter housing. Don't know if would work on yours.
Further thoughts
Jerry Gibbs
Bought my 1200 from a friend. His experience was that it did not work as a whole shop system. I keep mine as close to the machines as possible, switching a 4" hose from TS, sander, router, planer. I keep two 3" hoses connected to the TS blade guard and RAS. Dust collection shrouds are a major issue. Jerry
Dave Paine
I have the DC100C which means it has a canister on the top and plastic bag with snap ring on the bottom. As another reply stated this fits inside the steel shell in a special lip, so check that you model has the same shell.
The only nuance with the snap ring, is that you have to wrap the top of the plastic bag around the ring. Sounds easy, but doing so single handed can be frustrating. I get one portion to wrap and another portion unwraps. With two people it is much easier. Once prepared it only takes a few seconds to install.
Removing a bag can be tricky if you want to reuse the bag. The snap ring is strong and a tight fit. I have to be careful to get some implement behind the ring to pull it forward so that I do not tear the plastic. I normally empty these into cheaper bags for disposal and re-use the thicker bag.
The models designed for two cloth bags may be a different style of shell. Also if you replace a cloth bag with plastic, you are reducing the available surface area a lot which can result in greater pressure drop and so less suction. The canister model overcomes this by having much larger surface area.
I recall some Wood magazine article a while back which talked about cloth bag surface area. A manufacturer of cloth bags recommended users to switch to low micron rated bags since they were designed for reduced pressure drop and so better performance. I do not recall the name of the manufacturer.
For my purposes the 1100 model has adequate airflow/suction, but I only use one blast gate at a time.
Rick Haverstock
Dave,
Thanks for your information. I too plan on only using one run at a time through the use of blast gates. I'll have to check with the Jet people, but it appears that I have a channel inside the bag hanger sheet metal (although it's pretty shallow). As far as performance against the felt bags, you should look at the Wynn filter website. Bill Pentz recommends them and I think that he's right on that subject. With a large pleated filter you have far more square inches of filter media, meaning less back pressure/static pressure. Pricey yes, but so are the high filtration bags. They have converted Jets, Deltas, Harbor Freights and a number of other 1.5-2.0 HP collectors and have documented results. And somehow, don't you think that a filter bag manufacturer would have a dog in the hunt and push their own product??
Rick
Todd Nebel
Dave, you are rigth on with the hassel of getting the plastic bag off and on again. I too reuse the heavy plastic bags and find myself covered in saw dust when it comes to emptying the bag, not to mention the plume of dust that goes airborn. I think it's a bad design. My older PSI dust collector with a cotton bag strapped on the outside wasn't so messy to empty and it was a whole lot quiter.
need a hill
Jerry Gibbs
I dump the sawdust over the edge of my lot. Everybody needs a hill. I call it mulch.
Dave Paine
Todd, I have evolved a process to attempt to minimize the dust plume.
I set the Jet bag on the ground and then I cover the Jet bag with my disposable bag, then I do an up-and-over into a 45 gal can I have on hand.
I then carefully remove the Jet bag while trying to keep the mouth of the disposable bag as closed as possible.
This saves a lot of dust. If the weather allows, I do this outside.
Re: Further thoughts
Rick Haverstock
Jerry,
Thanks for the feedback. I think you should take a look at Bill Pentz' website. You're choking the system performance using three or four inch hoses. There is way too much info on his site to digest at one sitting, but after several readings I'm beginning to get it. I plan on using 6" all the way from the blower to the tool dust hood (which will also be changed out to 6"). Right behind that snap-on wye on the blower is a big fat 6" duct just begging to give you better performance.
Rick
Pentz website: http://billpentz.com/woodworking/cyclone/index.cfm
Robby Wright in San Marcos, CA
I have a Seco 2 HP collector that is similar to the Jet. One of the best things I did for it was to replace the top bag with the 1 micron bag from Rockler. The replacement bad is 6 feet tall and is made from felted material, not woven. When I first installed it, it flowed so freely that it didn't even inflate completely. Now that it has developed a bit of a dust cake, it does inflate. There is a loop on top that I secured to a screw eye in the ceiling to support the bag. I knock the dust cake off the sides every now an then to keep it from getting too thick. I no longer have dust on the walls near the collector. One of the best $30 I ever spent!
Robby Wright
