ADVERTISE HERE - FREE TRIAL
OT - anti liming
OT - anti liming
OT - anti liming
Robert R. Clough
Other than white vinegar, do any of you know of anything I could add to the water for our evaporative humidifier (and no, I would not use vinegar!). We have very hard water and I am certain the wick will calcify fast and hard, and that gets expensive. We use between 6 and 11 gals/day, sometimes only 4.
Re: OT - anti liming
Dave Paine
Have you considered installing a water softener? Few hundred dollars to buy, inexpensive rock salt to regenerate. This would also help the water heater, coffee pot etc.
These work by adsorbtion in the media in the beds.
I think if you are looking to add acids to attempt to neutralize the calcium carbonate, this would be messy and likely more expensive to operate.
Bill Turpin in WNC mountains
How does the water get into the humidifier? If you pour it in, you could make a manual, small, not plumbed into the the house water softener. Also you could use bottled, expensive water from another source. Is there anywhere close with softer water that you could bottle yourself? In commercial cooling towers they use bleed off to lessen the dissolved solids concentration. Is that possible with your application?
Dale Warder
Assuming that the humidifier is a batch charged water wheel or similar as opposed to a humidifier attached to a water line, the normal treatment is to place treatment tablets especially designed for humidifiers in the water tank. Obviously the sludge must be emptied frequently, but the water wheel will not plug up from sediment. These used to be available from most hardware stores, and at one time from Sears. I have not used a humidifier in several years since moving to the south, where dry air is not such a problem, but this treatment was the norm when I used a humidifier and lived in the north.
Good luck
Dale
Re: OT - anti liming *LINK*
Available at Amazon
Tablets
Robert R. Clough
Bill, it is a pour in type. The water then is wicked up and a fan blows the air hopefully now humidified. We've had it only a week or so. Seems to work fine, better than the heated, steam types we've had, the last of which lasted less than a year.
Have you any plans for a manual softener? I never thought of that.
Do your local supermarkets have machines outside that sell filtered water? All ours do, locally, at 30 cents/gallon. Not sure if the mineral content is cleaned out - you'd have to check.
No plans. I was thinking about a scrap plastic tank with pipe fittings both top and bottom or bottom side. Intall valves at both ends and a strainer at the bottom to keep crystals in it. Fill with water softening zeolites, charge with salt solution, and pour your bad water in the top. Soft water drains out the bottom. When lime builds up, flush and re-charge. I think that you want to keep it full so that the zeolites do not dry out. If you think that a normal water softener deals with hundreds of gallon daily, a salt charge should last a long time depending on its size.
This is a tinkerer's dream. How creative are you? The tank could be a five gallon bucket from HD or Lowes. Use a through the wall fitting to install a valve only at the bottom. How about an Igloo water cooler that already has a valve?
We bought the cool mist humidifier with a transducer. I have to clean out the base about every other week and also run some bleach through the tank. I didn't like the thought of breeding mold with the wicks.
I do use white vinegar. But that is because it is inexpensive. I also rinse out the vinegar before use.
FredD
We use a Bemis Humidifier constantly in the Winter, it requires a Bacteriostat which is a quart of Liquid and very little added to each tankful.
Any Hardware carries them.
One is made by Bemis and another is one by Holmes.
A water softener will not keep you from getting Calcium Carbonate .
Our Well Water has nineteen grains of hardness without conditioning and that is not considered very hard water compared to some who have as much as 110 grains of hardness.
We have a good water Softener coupled with a large prefilter and a Carbon one also, still get the buildup, but it is confined to the filter that is in the Bemis and that is replaced annually , sometimes twice.
FredD
Robert R. Clough
Thanks, Bill. I had never looked into water softeners and had no idea how they worked. Your suggestions are good. As I am a Tinkerer, Handyman, Builder of "Things" and "Devices" (that actually work), and so on, I may well give it a try. However, right now I think I'll try the tablets.
Robert R. Clough
Well we also use vinegar, but on the tea kettle and coffee maker. I shall use it on the wick but also want to keepe the wick from getting crudded up.
Jesper, Denmark
Re: Probably not the solution......
Jesper, Denmark
The water softener replaces the calcium with sodium, but does not reduce the salt content of the water. It just changes it from a calcium salt to a sodium salt. This is fine for washing etc. but in evaporative situations, you will still have the salt on the wick.
The only solution is demineralizing, which is comple�cated and not really feasible for home use.
Jesper, Denmark
Re: or......
Jesper, Denmark
condensate from a dehumidifier or condensing clothes dryer. Snow would work, but not the yellow kind.
Re: OT - I'm curious
Gary Camp, Bend, Oregon
Why do folks wish to add humidity to thier homes? The lower the humidity the happier I am.
FredD
Because your warmer at the same temp with 55% Humidity, then you would be at the same temp with relatively little humidity.
Because it saves the nice wood furniture from cracking and rupturing glue joints.
For those of us who suffer from dry skin itch , it keeps that down to a livable level.
Your skin doesn't take on a reptilian cast.
Your Leather goods benefit, for the same reason the wood does.
But different strokes for different folks who may have always wondered why the door openings changed size every change in the seasons without a little help from the inhabitants.
It is a healthy way to live, no dry nose, itch, less allergies and colds and blah blah blah.
FredD
Robert R. Clough
Well, Gary, with my lung and breathing problems I'd normally and theoretically agree with you. Certainly outdoors 40% is better than 70%. However, in the house less than 35% is not good: static electricity, cracked nasal passages, very dry throat, being cold, and having to have the O on all of the time is not what I consider salubrious. Obviously in the shop I do use O because it is very dry. Even outdoors I find it easier to breath during warm weather, even rather humid weather, than during cold weather when it is so dry.
I'm with you Gary
John in NM
The drier the better :D We like what we're used to I guess.
Re: OT - Thanks for the info.
Gary Camp Bend, Oregon
I hear so much talk in the summer about to much humidity, I just wondered what the reasons were for adding it to the air. I grew up on the wet side of the Cascade Mts. in Oregon, where 40 degs on a wet foggy day feels an awful lot colder than 20 degs here on the dry side of the mts. I just couldn't imagine adding water to the air. I guess it is good there are some many climate zones in this country. No mold and no rust here in sunny Central Oregon. It is a Blue Bird day here at work. Blue sky, Sunshine, 97" of snow, and 9 degs.
thanks again for the info.
Happy New Year to all
glc
