sorta OT and gross
sorta OT and gross
sorta OT and gross
woodenleg
My sons want to mount some deer skulls that don't have the bottom jaw. They say that we could use gel ca glue but Dad thinks epoxy would be better. None of us want to use screws. Any advance?
Thanks, Dave
Re: sorta OT and gross
I'd vote for a clear epoxy.
Clint Searl
How about a loose mount?
Clint Searl
There is already a pair of holes at the base of the skull, where the vertebra starts, that you can string a wire loop through to hang it from, with or without a backer.
Clint
jared
I have mounted several deer skulls by using some small diameter copper wire through existing holes in the skull. I just made a wood base out of some scrap wood, drilled holes that were about the same spacing as the width of the skull, strung wire thourgh the skull holes and then twisted the wire on the back of the wood base. They have been hanging in my shop for years with no problem. Jared
