Flummoxed by annoying posting problem
Bill Tindall
I just typed a lengthy response to the pig hunting question only to mistype something at the end and have the computer kick me back to my home page, thereby loosing what I had typed. This annoyance has happened on several occasions, invariably after typing long responses, and it involves some action of left hand's pinky or ring fingers (I touch type but am prone to hitting two keys at once) on the middle left side of key board and right hand on lower right part of key board. I have tried reproducing the evil by holding down shift key (in case I missed the caps key) and pounding away at everything my left pinky and ring finger can reach but could not reproduce the problem.
Any idea in the error of my ways?
Re: Flummoxed by annoying posting problem
Jesse Cloud
Depends on your browser. I use Mozilla Firefox and pressing control and w together has the effect you mention. Drives me nuts (short drive my wife says).
Don't know what's causing it, but
Henry Higginbotham
. . . any time you've spent more than 3-4 minutes on a post, it's a good idea to copy it to the clipboard just in case. Not that I can always remember to do that myself, but it's still a good idea.
Joe in a Cleveland suburb
Bill,
Jessee mentioned Ctr+W. If you are using tabs, I could see that happening. That is true with FireFox and IE.
Also, if you aren't using tabs (not the tab key, rather tabbed documents within the browser - hope that makes sense), and you are typing something such as a reply, and you hit Alt plus your Home key, you will be taken to your browser's "home page".
If that is the case, in most instances you should be able to hit your back button (or backspace key - depending on where your focus is) and return to the reply you were working on. FYI - I just tested that while writing this reply.
Just a couple random thoughts.
FredD
Like Joe says , the back button will work most of the time , and occasionally when I said to hell with it and closed WC there was the lost post ready to finish,
FredD
Steve Bistritz
Anything lengthy I usually compose in notepad, then copy and paste because of that exact reason.... :\
Control  Z   sonetine's will bring back your work
del schisler
some time's whan you miss type or delete someting in your text you can do a control Z and this will bring the text back to where it was . And than start the text over . I do this lot's of times.
Re: On my Mac,
del schisler
on the window's xp that works . I don't own a mac so thanks for replying on the mac. user's
