Another Shellac Question
Bob S
If I make a 1# cut of shellac, and apply it twice, is this basically the same thing as if applied a single 2# cut? I really like the manageability of the more diluted solution......
Thanks,
Bob
Bob S
Thanks,
Bob
Maybe
Depending on how you apply. Spraying 2 coats of 1 lb will equal 1 sprayed coat of 2 lb. If, however, you're padding it on, a portion of the prior coat will be picked (exchanged) by your pad. How much depends on how you pad. Same issue, but to a lesser degree, with brush applications. If you're hand-applying and want to build quickly, make one pass with the applicator and don't back-brush. You'll be leveling the finish later, so a few brush or pad strokes won't be a big deal.
hth
Re: Another Shellac Question
FredD
All things being equal the amount of the material would the same , but I would hit twice , just to make there were no holidays.
FredD
